Hi, got my home theater setup just the other day and just working on the finishing touches. I have a 7.2 (with 5.1 speakers) with 16ga wiring ran in-wall. I purchased banana plugs and this
wall plate/binding post that I intend on plugging the entire setup into the wall with. Well, My binding post and plate came today and when test fitting the banana plugs in the back and front of the binding post I noticed that both ends do not fit in all the way with both inserted. I am trying to find out if this is a problem or if I can just ignore this, I know I could connect the cables bare-wire to the back of the binding post but figured if I could use the plugs in the back I would since I have them available. I have attached some pictures and hoping someone with prior experience could tell me if this is an acceptable fit for in-wall.
Also, the speaker wire itself is CL2 rated however there is insulation inside the wall that the box will end up mounted in, should I heat shrink the plugs if I can use them or wrap with electrical tape?
