I am planning on using Winegard GS2200 Sensar III Amplified HDTV antenna to get TV reception. My equipment I am using is a Denon AVR 1713, Panasonic plasma TC-P50GT50, Energy RC-Micro 5.1 Home Theater System, and PANASONIC DMP-BDT220 DVD player. What would be the best way to hook this up. I have a similar configuration using FIOS and got that to work but have never hooked up a system with just an antenna. I assume I will be able to get 5.1 surround sound I hope. I am sort of up on these things but am no expert, probably would consider myself as knowing enough to do basic things. Any advice/help would be most appreciated.
AVS › AVS Forum › Audio › Receivers, Amps, and Processors › How can I use an HDTV Antenna with Denon AVR-1713
Featured Stories
Topics Discussed
Related Forum Threads
- Denon AVR acting erratically all of a sudden Last post on 5/12/13 at 6:31am in Receivers, Amps, and Processors
- Very new, and feeling overwhelmed, so seeking help with speakers for Denon AVR-1713 Last post on 5/7/13 at 12:57pm in Speakers
- Yamaha v475 vs Denon AVR-1713 Last post on 4/21/13 at 6:11pm in Receivers, Amps, and Processors
- Seek help using Dell 5.1 Speakers with Denon AVR-1713 Last post on 3/22/13 at 10:01am in Home Theater In A Box
- Problem about between Denon AVR-1713 and Panasoinc Blu-ray Player (DMP-BD77) Last post on 3/16/13 at 8:51pm in Receivers, Amps, and Processors
Gear mentioned in this thread:
post #2 of 21
1/7/13 at 6:58pm
post #3 of 21
1/7/13 at 7:55pm
- kousikb
- Trader Feedback: 0
- offline
- 285 Posts. Joined 4/2007
- Select All Posts By This User
post #4 of 21
1/7/13 at 8:45pm
- afrogt
- offline
- 19,884 Posts. Joined 7/2003
post #5 of 21
1/8/13 at 3:05am
- jdsmoothie
- AVS Addicted Member
- offline
- 34,425 Posts. Joined 9/2007
If you only wanted to use the antenna to pull in FM radio stations, you could connect it directly to the FM antenna input on the 1713; however, as AVRs do not have TV tuners, in order to use it to pull in TV stations, you'll need to connect it directly to the TV as others have noted. Rather than using ARC (as it can likely only pass stereo 2.0 audio), you'll then want to connect an optical cable from the TV to the 1713 which will allow the TV to pass DD 5.1 on those HD stations that broadcast DD 5.1.
Also note, there's a dedicated thread for Denon AVR-XX13 Owner's linked in my sig. Review posts #3-6 in that thread for additional helpful information.
Thanks for the info. If I used an HDMI cable from the TV to the Denon would this mean I could not get 5.1 sound ? My home is new construction and have it prewired from wall where TV will be mounted to AVR rack with HDMI, did not put in any other type of cable. The TV supports ARC from what I can gather. Also is there some device I can purchase which can receive the Antenna signal, pass it to the Denon, and then to the TV like would happen if I had a cable or Fios box ? Any help would be greatly appreciated.
post #7 of 21
1/8/13 at 10:13am
- kousikb
- offline
Your options are limited if you need 5.1. But you can go with (1) Samsung DTB260F (truly independent) (2) New Boxee box (3) simple.tv with Roku (not sure whether you will get 5.1)Originally Posted by nygman5
Thanks, would the Channel Master CM-7001 work for my situation. I have read some of the info here and I think so. I want to have 5.1 sound if at all possible. If I run the antenna directly into the tv and use HDMI to the Denon would that produce 5.1 sound ? I am somewhat confused by a previous post. The TV supports ARC. Appreciate all the help.
post #9 of 21
1/8/13 at 10:55am
- beboram
- offline
- 302 Posts. Joined 11/2001
First, I would recommend a rooftop TV/FM antenna with a rotor if needed. Then add amplifier if still canot get strong signal by pointing the antenna to the right direction. Check TVFool.com for antenna choice.
Second, it is not difficult for a professional antenna installer to pull a cable directly to your TV. That will be your best choice for over the air (OTA) broadcasts. My house was not wired for antenna either but the antenna guy did it in a snap with no damage..
post #10 of 21
1/8/13 at 10:59am
- kousikb
- offline
Yes CM7001 would work as well and so would be the DTVPal DVR. The ARC feature is a new feature useful for people with OTA connection to TV or apps (e.g. netflix, amazon VOD) within TV sending the audio channel to the receiver. As you can imagine, the standard might have dictated something and the implementation might be conforming to the standard and still pass "more" on top of the standard. Disclaimer: I don't have ARC capable tv or receiver, so I am not the best person to talk about it. But definitely I am also interested in this type of technology because I used to be an OTA enthusiast, and simplifying the number of boxes, cables interest me. Here is a relevant discussion on ARC/CEC which might warm you up on the various issues/gotcha on CEC/ARC.
http://www.avsforum.com/t/1253575/samsung-c8000-and-audio-return-channel-problems
Hello, I am planning on setting up my system this weekend and am still not sure if I need an HDMI cable to the Denon or an optical. A helpful person posted "If your TV supports ARC (Audio Return channel), enable it via the menu and connect the receiver to the TV via a HDMI cable which supports AC." The TV supports ARC so I think I can as there already is an HDMI cable running in the wall from the TV to the Denon which I can hook up. I am not sure what "supports AC" above means. The cable is hdmi version 1.4 as it was purchased and installed this summer by the electrician when my house was built and he told me it was latest specification cable.
I hope my questions don't seem too dumb and I appreciate all the help
post #12 of 21
2/13/13 at 6:04pm
- GaryWA
- offline
- 331 Posts. Joined 1/2013
The HDMI will work, just enable HDMI-ARC or CEC in the TV settings. However, it can NOT pass 5.1 back to the receiver, only 2.0, that's why some people suggested an optical cable, which can pass 5.1
post #14 of 21
2/13/13 at 6:20pm
- GaryWA
- offline
post #15 of 21
2/13/13 at 6:26pm
- old corps
- offline
- 899 Posts. Joined 12/2007
Yes they can. They're also called Toslink cables. This is THE place to get quality cables at a great price and they ship FAST. Toslink cables are down the page a little bit.
http://www.monoprice.com/products/search.asp?keyword=toslink+cables
Hope this helps.
Ed
post #16 of 21
2/13/13 at 6:26pm
- old corps
- offline
post #18 of 21
2/13/13 at 6:33pm
- GaryWA
- offline
Yep. I have the 8.0mm "fancy" one, it's a pretty nice cable.
post #19 of 21
2/13/13 at 6:34pm
- old corps
- offline
post #20 of 21
2/13/13 at 6:35pm
- old corps
- offline
- How can I use an HDTV Antenna with Denon AVR-1713
Currently, there are 1548 Active Users
(365 Members and 1183 Guests)
Recent Discussions
- › "Official" Audyssey thread (FAQ in post #1) 10 seconds ago
- › The "Official" Yamaha RX-V1800/RX-V3800 Thread 11 seconds ago
- › Official LG 84LM9600 (Ultra HD 4K) Owners' Thread 1 minute ago
- › Official Panasonic VT50 owners thread 2 minutes ago
- › Official Samsung UNxxES8000 Owner's Thread 3 minutes ago
- › Denon DVD-A1UD/DVD-A1UDCI Blu-Ray/DVD/SACD/DVD-A/ Universal Player 4 minutes ago
- › Detroit, MI - HDTV 4 minutes ago
- › Mitsubishi HC5 vs. Sharp XV-Z30000 as a single PJ solution 4 minutes ago
- › WD Red vs WD Green vs Seagate 3TB Hard Drive Speeds 5 minutes ago
- › Silver Linings Playbook (Blu-ray) Official AVSForum Review 6 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
