I was just looking through the last page of your build here and noticed you've posted a lot unanswered. Â Just wanted to say nice job. Â I like seeing the progress shots.
Â
Your screen wall is 14' wide, if I'm reading your diagram properly. Â I think a 96" wide 2.35 might be too small. Â If you keep it at that size, though, I would say your seating would be ok pushed forward. Â If you bumped your screen to 110", you'd be pushing it. Â Generally, your screen width to distance from screen ratio should be about 1.25, and never less than 1. Â I have mine at 1.2, and many people say "it's almost too big" when they see it at first. Â Of course, like most big TV's, you get used to it after awhile and it's perfect. YMMV, but the 1.25 is a good target to aim for.
Â
I have low ceilings, like you, and a 2.35 screen made more sense because it's short/wide, unlike a 16:9 screen with is tall/narrow. Â If it were up to me, I'd keep the jive seats a little off the back wall (a foot or so) and make your screen bigger. Â That's just my opinion. :)
Â
Keep up the good work!
