Ok so after a lot of reading I have a couple of questions.
If I were to get IR can I not run the break in slides overnight to help get rid of it?
Also when I did run the break in slides i did it under a "short" display interval (the fastest one) thinking that would be right and woke the next morning seeing a flicker almost between the slides? what interval should it be run? Did I hurt the tv?
THNX,
PAUL
THNX,
PAUL
