Only difference between HT-E6730W / HT-E6750W is the later has a tall boy surround speakers in AU market, while E6730W in US market with only small surround speakers.
Pros:
Cons:
Please feel free to add your opinions here.
Edited by MickeyJC - 1/7/13 at 10:36pm
Pros:
- Good Sound quality when turned on 3D sound option (High/Medium/Low) to activate Simulated 7.1 channels
- Wireless Surround Speakers can pick up signals with no delays
- Vacuum tubes which boosts up sound performance
Cons:
- Audio Sync (Lip Sync) option only works for Bluray Source, It doesn't adjust the sound delay for Optical / Digital Input, Neither for the Direct Media File playback from the Front USB panel. (To be Confiemed), Hoping Samsung will have a firmware update to solve this issue.
- Not a true 7.1 channel system, does Not support "Dolby Pro Logic IIz". Samsung implement its own "3D Sound" feature, which has the same spec as "Dolby Pro Logic IIz" adding extra two channel to the front top speakers. Maybe they are trying to cut down the cost by not paying for the extra Dolby license fee.
- No Direct input Source button / IR command; this makes Universal Remote (such as Logitech Harmony) have to run through a Source Cycle, Most of the time it will not reach to the desired source input due to timing, fine tune is needed.
and told me it 's real 7.1
