AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Acer H6510BD - FullHD 3D DLP DC3 for under 1000$?
Acer H6510BD - FullHD 3D DLP DC3 for under 1000$? - Page 11
post #301 of 510
Originally Posted by jaz50y View Post
Thanks to rnatalli for Projector Cental info. It's a good start. I have a new problem. I watched a Netflix streaming movie on my PS3 for the first time, and every so often, maybe 5 to 10 min intervals, the video signal would be lost, the screen flash bright static for a second, then return. A couple of times the Acer lost the video connection altogether, which took a few seconds to correct. No problems with my Verizon Fios, haven't tried a dvd. The PS3 gui is stable (and looks great!). My setup goes PS3 > HDMI > Monoprice 1x4 switch > Monoprice 34' HDMI to DVI cable > Monoprice DVI to HDMI adapter > 3' HDMI cable > Acer.
Never had this problem with my Barco 808 (which was modified for 1080p), tho the DVI went straight in, no adapter.
That 3' hdmi cable needs to be the same gauge as the 35' cable.
If you do a search on avsforum you will see that people using hdmi switches have a lot of problems with the switches. For short runs to a TV they are normally fine but when dealing with a projector or distant TV they are problematic. In your case the problem is probably the gauge wire of that 3' cable. Good luck.
post #302 of 510
still waiting for my disney wow blu ray, itll be here tomorrow. Havent used the projector since and I've been using my plasma, it's shocking how different it is in the terms of blacks and color lol it's so weird.
post #303 of 510
disk still isnt here yay
post #304 of 510
At least you have the projector. Amazon still hasn't shipped mine (ordered on April 12th). They show it will be delivered by this Fri. but not looking good.
Update: Just talked with another Amazon rep who told me it will be delivered by tomorrow (5/17). It still hasn't shipped so that's going to be a neat trick if it shows up.
Edited by terry2 - 5/16/13 at 4:26pm
post #305 of 510
Ditto. Ordered mine May 5 - estimated shipping date is May 21 - 24.
Beachaudio (thru amazon) currently has stock but at around $50 more than what I originally paid for.
post #306 of 510
Ordered mine through newegg. Should be here tomorrow. This is my first projector. So can't wait to see how a home theater projector setup is.
post #307 of 510
hha you sound like me when I custom ordered my 5.0 this year, longest 10 weeks of my life.
I just bout this bout 2-3 weeks ago from newegg with free two day shipping for $620. Ordered tuesday got it thursday at 9 am.
You are gonna be wowed.
post #308 of 510
please post your calibration settings after calibration. Saves everybody time and a little money.
post #309 of 510
We all have different set ups so that's not going to help, I hope I receive it today. I know that turning brilliantcolor OFF makes everything 100 times better, and so does turning dynamic blacks ON.
I have tried different calibration settings for my other TVs be LED or plasma and they all look dull and terrible so I'm not even gonna bother.
post #310 of 510
We know we all have different setups but if what you post doesn't look right all we need to do it reset. It is just a guideline and better than hit or miss when no one wants to share info.
post #311 of 510
Same here. I feel turning BrilliantColor OFF makes colors much better, atleast for nighttime viewing. Somehow I didn't like dynamic blacks ON. It whitens the entire image and actually decreases the contrast.
Exactly. Last time I did this on LCD TV, I puked at the image....was wondering if that's what video purists really crave for and quickly adjust the colors back up to what our eyes like. So, I am not bothered either too much about calibrating, although it would be interesting to see how calibrated image looks vs. what our eyes like.
post #312 of 510
Well it makes the colors "pop" more with dymanic blacks in my opinion! and I have double checked while doing the calibration that it does not affect whites not blacks!
Here are some pictures after an hour of calibrating, they do no justice to the image in person but I am 100% happy with the result! They were taken with the crappy iphone 4 camera
post #313 of 510
In my experience calibration disks aren't really that helpful for adjusting color but are great for properly adjusting gamma, brightness and contrast. Brilliant color on with white peaking set to minimum provides the best picture in my opinion. I also like dynamic black. I believe dynamic black has to be enabled for you to get the full 7000 hr lamp life on eco.
I would suggest not messing with the advanced color section unless you write down the beginning settings.
post #314 of 510
I messed with them, and it worked out thank god hahah
post #315 of 510
Well finally got mine in today. Got it setup and all I gotta say is WOW! You were right Kevinlg. Best $800 I've ever spent.
post #316 of 510
It just went on sale again on newegg for $699.99
post #317 of 510
post #318 of 510
And with this code EMCXRWN44 you'll get another $70 off = $630.
*Oh and they have $ .99 3 Day shipping as well.
Jason
Edited by DaGamePimp - 5/17/13 at 3:02am
post #319 of 510
Cancelled amazon order. Pulled the trigger with the newegg 630 promo. Thanks for the heads-up!
post #320 of 510
Well that's great I bought it on Tuesday for $799 and two days later it drops $100...
post #321 of 510
I just bought this earlier with the NewEgg deal, pulled the trigger on the spur of the moment due to the unbelievable cost. However, after searching around for some additional information on this projector (I was planning on the BenQ 1070 before this) I saw something that I'm quite concerned by - the 3d is supposed to just be at 96hz refresh, not the 120hz that seems standard. My main reason for picking this up is for 3d as I have an existing non-3d projector that works just fine. Anyone with this projector who uses it mainly for 3d that can compare it to another 3d projector running at 120 hz refresh? If it really does show up noticible flicker I will cancel and pay the extra $200 for the Acer. Thanks!
post #322 of 510
I just canceled my Amazon order that I have been waiting to ship since 4/29... and pulled the trigger on the New Egg deal.. Came here to post a heads up for others, but I see I am late to the party.. Now I need to finish by theater ASAP.. because the wait for the projector will be over shortly!!
post #323 of 510
I've has over 4 3d hdtvs and ive obviously been to the movies to watch 3d and not ONCE I've had eye strain from 3d, but with this projector even for less than 20 minutes I feel like gouging my eyes out I don't even know why:mad: the 3d is beautiful but the colors are NOT. every time you calibrate 3d and go back to 2d, 3d goes back to some stupidly bright settings.
btw CONGRATS ON ALL WHO BOUGHT FROM NEWEGG, remember to sign up for shoprunner and get free 2 day shipping on top of that good deal.
post #324 of 510
Cancelled my Amazon order too. They still don't have them and newegg's price is right.
post #325 of 510
I bought this projector this week and it arrived today. I'm very satisfied with image quality, however the one thing that I noticed is that mine is quite loud and suffers from a buzzing sound (originating close to the lamp I think); My previous beamer was also Acer and in Eco mode it was very silent. This one however has aside from the air pumping out a buzzing sound that changes whenever I tilt or movie the projector (intervals become faster and slower) and even in eco mode it's there. I'd like to know if this is normal or if I should consider sending back my projector for a replacement. It's really intrusive when there's a silent scene in a movie.
post #326 of 510
While the w1070 bests the 6510 I have to be honest here and say that is one heck of a deal at $630 and even though I have 3 pj's here already I am tempted to grab one strictly as a gaming pj since it certainly has the lumen's to fill my 133" with some goodness.
My concern would be regarding lack of proper calibration ability built into the unit but at this price and for gaming it's going to be tough to pass up... redface.gif
That sounds defective to me, I would exchange.
Best of luck,
Jason
post #327 of 510
Best of luck,
Jason
Thx Jason! I suspected as much. Will contact the store tomorrow and set up an exchange.
P.S. I'm jealous of all the great deals you are getting in the States, very hard to find it over here under 700 euro.
post #328 of 510
Well that deal just SOLD OUT, and I just went to order one after passing on it last night... lol.
Jason
post #329 of 510
Best of luck,
Jason
If you have a colorimeter this thing has a CMS so you should be able to get it to where it is really quite good. With my unit brightness, contrast and gamma are quite accurate out of the box. Colors look oversaturated but I've seen much worse on TV's that cost just as much or more.
If you keep an eye on it you might be able to grab one at $630 still.
Bumblefeet, that is definitely defective. Mine is silent. I would guess it is a ballast but I really don't know.
post #330 of 510
you're moving it so the fan is hitting something so it's normal
and yeah this projector sounds like it's about to take off in eco mode.
