Hi,
Trying to calibrate my Samsung E8000
Have a pioneer blu-ray player and Boxee Box as sources
My question is which of the HDMI outputs are "best"
My pioneer blu-ray is default set to YCbCr 4:2:2, I changed this to YCbCr 4:4:4 because this is what i set my Boxee Box to output too
(when i choose RGB low or RGB high on the Boxee Box I can not see more than 4 line flashing on AVS 709 white clipping but when i choose YCbCr 4:4:4 I can see them all)
not sure what to choose...
my gut feeling says choose RGB since it is digital, but then i only get 4 lines in AVS 709 white clipping.
my choices on my pioneer blu-ray is
YCbCr 4:2:2
YCbCr 4:4:4
RGB
FULL RGB
my choices on Boxee Box are
YCbCr 4:2:2
YCbCr 4:4:4
RGB LOW
RGB HIGH
which one should i choose?
confused noob :P
YCbCr 4:2:2
YCbCr 4:4:4
RGB
FULL RGB
YCbCr 4:2:2
YCbCr 4:4:4
RGB LOW
RGB HIGH
confused noob :P
