AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official Panasonic TC-PxxST60 Series thread
Official Panasonic TC-PxxST60 Series thread - Page 120
post #3571 of 12325
Originally Posted by HD2Blu View Post
He knew what he was doing and had had several years of experience dong
You made me spit my soda pop on my monitor. I laughed for a few good minutes.
post #3572 of 12325
Originally Posted by BruceOrlando View Post
Installed the Inspired LED strip last night.
Thanks for the heads up everyone!
The "Dude" abides ...
post #3573 of 12325
not if you buy the 55 or 60 "for a distance of 9,8 feet, who can give me information on stock miami where there in the 60" because that sears sold the 55 ", thanks!!! sorry bad english
post #3574 of 12325
Originally Posted by noobhere View Post
So the S64 has the same PQ as the ST60? I noticed that the S64 also had the pro settings.
No. The ST60 uses a more advanced higher-performing panel than the S60/S64 does so the overall PQ will be better on the ST60.
post #3575 of 12325
How close is your tv to the wall? I have my 60" wall mounted and was considering that LED strip, but Im afraid that it wont be bright enough/the wall will absorb the light because the strip is too close to the wall.
post #3576 of 12325
Sorry to beat a dead horse, but what's your opinions of ST60 vs VT50? Someone living out of country wants to buy one. I haven't personally seen the ST60 either, but will later tonight.
post #3577 of 12325
D-Nice stated that the colors are about the same. Although from the calibration reports I have seen posted the VT50 can be dialed in closer to perfection. He also said the ST60 blacks were better. Long term settings might be more stable in the VT50 but time will tell in the ST60.
post #3578 of 12325
Originally Posted by hank0 View Post
In general, is Panasonic just terrible at updating their products firmware? I know the lag has no chance being fixed because the firmware is design like it is and panasonic wouldn't want to try and problem solve it. But, the no 48hz in 3D is unacceptable, since the ST50 only looked good in 48hz. Would a firmware update to enable 48hz be simple for panasonic?
GOOD QUESTION! We all should get on the horn with them and complain/ask about this issue.
post #3579 of 12325
HA! I missed that one the first time I read it.
post #3580 of 12325
Does anyone know if that's because, that is how the 2500 FFD (Focused Field Drive) handles motion?
Maybe...I kinda thought that stuff was all a gimmick but maybe not.
Was the 50 series the first year they used the 2500 FFD? I never had a 25/30 series to compare my 50 to though so...?????
post #3581 of 12325
I posted Thursday about how the Best Buy premier silver membership offered a FREE calibration.
The geek squad guy just left. We ran a few demos and I can't wait to play around with these new settings more. My first impression was it would have been totally worth $250! What he did was awesome! He knew what he was doing and had had several years of experience dong this (that being said - each tech is going to be different) I'll post more thoughts and the settings later tonight, but VERY impressed with what he did. He showed me some per-calibration charts and actually the settings I got from AVS were pretty close but pushed too much red (ever so slightly) now they are all even.
BTW he just calibrated a Samsung F8500 last week and did a ton of VT50s last year. He said based on what he saw - he thought this TV was almost better than the VT50 and for half the price of the F8500 he was super impressed with what the ST60 could do. The only thing he wished the ST60 would have had is the secondary color settings. H couldn't get the yellow, cyan, and magenta EXACTLY where he wanted them but he was pleased with it non-the-less. He said the human eye wouldn't be able to detect the difference.
I'll post more later.
Yeah my impression while comparing the 8500 and the ST60 at the store was that the ST60 was right there with the 8500 or at least not far behind (the 8500 was brighter). For half the price at that. They were the best 2 panels on the wall (VT60 wasn't in yet). But it is nice to hear another "pro" corroborate what I am seeing.
Edited by wattheF - 5/4/13 at 11:21am
post #3582 of 12325
Dong Squad. That sounds about right.
post #3583 of 12325
Originally Posted by mike_n03 View Post
I had the same issue pop up on my p60st60. After going through the same process you did,the way I corrected the issue was to cycle off the power of tv and the devices. Then turn on the tv and make sure you have it set to the hdmi input you want to use before powering up the device.
This has solved my issue, just make sure the tv is on and set to the input you want before turning on the hdmi device. I guess it has something to do with how the tv handles the handshake between the two devices.
I have the same issue but these steps didn't work for me.
My PS3 worked great on HDMI 1. When I powered down the TV and PS3, changed the cable to HDMI 2 and powered the TV then PS3 on I get the "No signal" message on the TV.
I even tried unplugging the power cables of the TV and PS3 for a couple minutes, reconnecting and powering on, but it still didn't work (via HDMI 2).
Is there anything else I can try to get the HDMI 2 or 3 inputs working?
post #3584 of 12325
post #3585 of 12325
Originally Posted by wattheF View Post
+1 !
post #3586 of 12325
Nice! Where'd you buy the strip (do you have a link)?
post #3587 of 12325
Look around the web, make some phone calls in Miami !! Do what you have to do.. It's not hard to call and ask if they have the Panasonic plasma 60ST60 in stock - make it happen !
post #3588 of 12325
There's someone in the S60 thread having HDMI problems too. Could be a problem with these TVs.
post #3589 of 12325
Can someone tell me how to play slides from USB. I searched the manual, only shows me how to remove USB. When I plug in the USB nothing pops up asking to play.
I am playing them from the PS3 using DLNA media streaming for not just not sure how to do it from USB at Dnice had intended
MN figured out there is a media player under apps
Edited by wirelessroute - 5/4/13 at 11:41am
post #3590 of 12325
Hit USB on TV remote - done.
post #3591 of 12325
Originally Posted by ThrowingChicken View Post
Anyone else hit the exit button on the remote while having the menu up during app/usb/Netflix content and have the whole thing exit to the home screen?
i believe you may be hitting the Home button when toggling the arrow buttons . I did quite it a few times when setting it up, since toy are looking at the screen and using your thumb. It got frustrating. Terrible spot location in my opinion
post #3592 of 12325
Duh! all hidden in bottom right SD/USB LOL good looking out bro!
post #3593 of 12325
No worries.. So many things to consider in these menus, on these expansive remotes.. Enjoy !
post #3594 of 12325
Can someone post the best settings for 3D. Playing with it now set motion smoother to weak and off still getting some cross talk
Using home theater mode for settings
This what I found from a review site
through the Custom setting (Motion Smoother to Strong setting, 3D Adjustment setting to +3) we got a very solid 3D picture that popped
Tried it not to bad, any other suggestions for optimal 3d experience with minimized cross talk ?
Edited by wirelessroute - 5/4/13 at 12:05pm
post #3595 of 12325
Okay now from personal experience I have tried 6 different settings (all other people who calibrated their individual sets WITH equipment) but here is what my calibrator came up with today on MY set. Let me know if anything sticks out to you, but I am super pleased with these on MY set.
Side note: I used one of the settings I got from another member on here and they were pretty close to inline calibration on his computer but the reds were high so don't be surprised if you see something different on your set when you plug these in.
Custom
Contrast 89
Brightness +3
Color 52
Tint 0
Sharpness 45 (personal preference)
Color temp - warm 2
Vivid color - off
C.A.T.S. - off
Video NR - off
MPEG NR - off
Motion smoother - off
Pro settings
Panel brightness - mid
AGC - 0
Black extension - 0
Color gamut - normal - side note: set to Native if you want an LED looking colors
W/B detail adjustment
High R 0
High G 0
High B -3
Low R 0
Low G 0
Low B 1
More detail adjustment
10 IRE -13, -2, 9
20 IRE 9, -4, -10
30 IRE 5, -4, -12
40 IRE 6, 0, -6
50 IRE -1, 0, -10
60 IRE 0, 0, -8
70 IRE -7, -2, -2
80 IRE -6, 2, -4
90 IRE -6, -2, -3
100 IRE -9, 0, 6
Color detail adjustment
Red hue -4
Red sat -2
Red lum -2
Green hue 1
Green sat -37
Green lum -1
Blue hue -2
Blue sat -18
Blue lum -12
Gamma detail
2.4
10 IRE -2
20 IRE -2
30 IRE -1
40 IRE -1
50 IRE -1
60 IRE -1
70 IRE -1
80 IRE -1
90 IRE -1
100 IRE 0
Game mode - off
24p direct in - 60hz (personal preference)
1080p pixel direct - off
3:2 pull down - off (greyed out)
Black level - light
Screen settings
Overscan - Off
H size - 1
Screen display - on
4:3 side bars - high
Pixel orbiter - auto
post #3596 of 12325
For 3D, if you leave motion smoother to off or weak you're more likely to get crosstalk. It needs to be on mid or high.
That's what I've seen.. Haven't tried 3D yet. Got an Oppo 103 yesterday, need to setup this bad boy and maybe watch Avatar 3D later tonight, it's just too nice outside right now, summer in the Nations Capital much better than winter cool.gif
post #3597 of 12325
Hey guy just got my st60 this week, looks great but I can seem to find a good mount that swivels and extends. What is the consensus on the best wall mounts for this tv?
post #3598 of 12325
Check out Monoprice !
post #3599 of 12325
Agree, mid or strong. Weak does not do much. Also, -3 if you want more popout. +3 will push everything back more into the TV. That is personal preference on what you enjoy more.
post #3600 of 12325
Any suggestions on whether to set it to 96hz or 120hz (under 3D settings). I watched Avatar last night (it look great by the way) and I kept switching back an forth from 120hz and 96hz. I really didn't notice much difference between the two. My eyes did seem to get less fatigued when set to 96hz (but that could just be in my head)rolleyes.gif
Edited by supermandlb - 5/4/13 at 12:59pm
