AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official Panasonic TC-PxxST60 Series thread
Official Panasonic TC-PxxST60 Series thread - Page 253
post #7561 of 12340
Originally Posted by cyberbri View Post
There should be a standard headphone jack on the TV, by the card slot.
Looks like only the Europeans rate a headphone jack.
post #7562 of 12340
Originally Posted by ricardoht View Post
Is there a way to turn off the speakers? I'm planning on using a Onkyo AVR.
I think if you go to the "Viera Link" app and change it to "home theater" it turns off the TV speakers. You need ARC to use the app.
post #7563 of 12340
that's right, and it has own volume settings in menu.
just turn down speakers volume.
post #7564 of 12340
My speakers are completely off when turned down to "zero"". We play thru a JBL soundbar in a smallish condo LR.
post #7565 of 12340
Does anyone know why I can't get uncompressed audio when watching a 3D movie on a PS3? If I switch to 2D I get uncompressed audio. Is it just a setting or do 3D movies not have uncompressed audio?
post #7566 of 12340
Is the PS3 hooked to your receiver directly over HDMI? Watching 3D, maybe there's a different default audio setting, so you have to manually change it? Or maybe it's limited bandwidth over the HDMI cable, because of the 3D? I don't think the last one should be an issue with the HDMI 1.4 rated cables/equipment, though.
Maybe that's a question for the PS3 thread probably, unless someone here knows.
post #7567 of 12340
Everything is connected HDMI with 1.4 cables. I changed audio settings to get TrueHD but it only works in 2D.
post #7568 of 12340
I may be off on this, but if I remember correctly the ps3 can't do 3D and lossless at the same time
post #7569 of 12340
Can it do 3D and PCM, if it decodes and sends PCM instead of lossless?
post #7570 of 12340
Received my 50st60 a couple days ago (about 60 hours into slides). Cant comment much on PQ yet, but I must say I was a bit anxious about all the reports of buzzing in these PDPs. So far, no matter how hard I try, I cannot hear any buzz what-so-ever. Am I just fortunate, or did I attend a few too many rock concerts? This is my second Panny plasma and the first was dead silent as well. I do utilize a lower-end Panamax unit for surge protection which also purports to "condition" AC supply, so maybe that helps as well.
post #7571 of 12340
Too many rock concerts, just kidding, all plasmas buzz to some extent but some can be louder than others. My GT50 is pretty much silent as well. Consider yourself one of the lucky ones. biggrin.gif
post #7572 of 12340
LPCM is lossless, if it's the result of decompressing a lossless bit stream.
post #7573 of 12340
From what I found on the internet the PS3 can't do 3D and Dolby TrueHD at the same time. I guess it's time to buy a 3D Blu-ray player.
post #7574 of 12340
How do I find out what the Panel Setting is when the Pro Setting option is grayed out under the Standard?
post #7575 of 12340
Pro settings are only available in cinema and custom modes.
post #7576 of 12340
I haven't been on AVS in a while, but I'm still loving my 60ST60. Watched Cloud Atlas 2 nights ago, Looper last night, 2 great movies and PQ was top notch. That said, up until recently, I never had any IR, and it's not a big deal, but I'm hoping in time it will go back to being the zero IR display that it used to be. Not exactly sure how many hours I have on it, but I would guess somewhere around 400. I mean, I just did the software update about 15 minutes ago, and I can still see the 'updating software' text on a light background. Besides this weird IR phase, I love the display, much more than the F8500 I had before and all the LED/LCDs I had before that. It's simply an amazing display, and I have no inkling, not even an inkling of an inkling, to upgrade anytime soon or far.
post #7577 of 12340
Originally Posted by Bond 007 View Post
Whats your source? Many cable boxes have audio settings. Look for an audio "Range" setting. Mine has Normal, Narrow and Wide that will affect the volume on the tv.
Brilliant! I'll check. Thanks for posting.
post #7578 of 12340
Found the setting, changed it to "wide" and problem solved. Thanks so much!
post #7579 of 12340
Reflections???
Trying to get an idea how relfective this set is. Hard to tell in Best Buy. My living room is not real bright but has a kitchen behind with overhead recessed lighting.
Coming from a LCD with matte screen. Tried a new Sony 550 with semi matte that is still very relfective. Sony going back due to clouding. Would the ST be similar to the Sony?
I tried a Panasonic S1 a few years ago and the glare was too much. Looking at the 65" ST.
Thanks in advance.
Ozzzie3
post #7580 of 12340
In the Pro Settings submenu: Panel Brightness, C-net suggests Low. Hometheater.com suggests Mid for 2D, and High for 3D.
Is there a consensus in this forum regarding the Panel Brightness setting?
post #7581 of 12340
Originally Posted by ozzzie3 View Post
Reflections???
Thanks in advance.
Ozzzie3
I think the screen is quite reflective. I purchased the Visio M series before my st60 and the screen reflectiveness is about the same. Even with the filter its a glossy screen, but its so glossy you feel like you are looking into a mirror (which is how i felt with the s60). My tv is in the living room with 3 windows including a large picture window and they don't cause me any issues.
post #7582 of 12340
YW glad it worked.
post #7583 of 12340
Mid for 2d and High for 3d is usually the correct panel brightness
post #7584 of 12340
Mid is too bright on 50 ST60 Eu ...
post #7585 of 12340
Anyone having success playing MKV files via the DLNA server?
post #7586 of 12340
I haven't been around much lately either (too busy enjoying my ST60!). I remember when you were contumplating the F8500 and other options. Glad to see you are happy with the ST60. As am I.
I don't want to scare you and I'm sure it varies by panel, but as my panel ages the IR has gotten progressivly worse. At first it was fairly ressistant to IR, now with about 6 mo. under its belt it gets IR VERY easily. Literally within seconds of having a still font on screen can cause it. I am not at all worried about it though because it ALWAYS goes away very quickly. Usually within seconds or at least minutes any traces of IR are totally gone.
So it has short term IR and no issues with long term or persistent IR.
This is just my experience and I'm not sure how it compares to others. I naturally vary my viewing content. It does not at all prevent me from recommending this TV to anyone (with exception to maybe hardcore gamers or those who keep their TV on ESPN all day). Loving it!
Edited by wattheF - 8/14/13 at 9:12am
post #7587 of 12340
So I've narrowed my purchase decision between the 60" ST60 and the 60" Samsung 8500. I am aware of the roughly $1,000 price difference between the two and that certainly is a factor. My only concern with the ST60 is that the picture may be to dim and coming from an LCD it may take some getting used to. A lot of reviews point out how the 8500 is comparable to LCD's in terms of brightness. I remember one reviewer on amazon pointing out that the only thing that takes getting used to on the ST60 is that sports seem a little dim. I guess he's comparing to an LCD.
So my question would be to owners of the ST60 is...do you ever feel, when viewing the ST60 that the picture is slightly dim and can use some "punch" (particularly when viewing sports) or do you feel it's just right and accurate? Thanks a lot!
post #7588 of 12340
Once you get the ST60 and adjust the settings I think you'll find its perfectly fine in most conditions and that many LCD's are painfully bright in comparison.
post #7589 of 12340
Thanks for the quick response. What settings would you (or anyone) recommend OOB for optimal picture and brightness without a professional calibration?
post #7590 of 12340
Painfully bright? Of course you could tune the LED down, which might also improve blacks. I had my heart set on a 65ST60 but finances are causing me to back off. What comparable LED65 would others consider?
Sent from my SPH-L710 using Tapatalk 2
