AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official Panasonic TC-PxxST60 Series thread
Official Panasonic TC-PxxST60 Series thread - Page 327
post #9781 of 12386
Got me the Yamaha rx-v475
post #9782 of 12386
Yamaha has always been a good choice smile.gif if you have istuff you'll like AirPlay. I use mine all the time.
post #9783 of 12386
I have a 60 inch ST60 coming tomorrow and I currently have this stand
http://www.crutchfield.com/S-U9eBqWqJHeX/p_571TRK50B/Techcraft-TRK50B.html
In the instructions it says it can hold a 50" TV or 125lbs max. Is this stand going to be ok for the ST60? I have had the stand for 5 years and it has been great. I wasn't really looking to buy a new one but don't want the TV falling over either. Is the weight of up to 125lbs ok to go by since the ST60 weighs about 70lbs without the pedestal?
post #9784 of 12386
Ya looking forward to using AirPlay!
post #9785 of 12386
How much better is the 65ST60 vs 65ST50?
post #9786 of 12386
What you need to be concerned with is the hole pattern on the back of the TV. Our Z-Line Designs stand is similar and just involved slightly changing the assembly of the mount. I just had to use the outside holes instead of the inside holes on the piece that it hangs on. You can look at the user manual to see the dimensions of the VESA mounting holes on the back and compare them to what you have now. Also, the Panasonic site has the correct wall mount that Panny suggests which will also show the hole dimensions. Our 46" Sony had holes that were closer together, which required the mount to be reconfigured.
post #9787 of 12386
Thanks Neil. Just looked at the current stand and the way its configured I think I should be ok. Was worried about "hanging" a much wider TV on it than my current 50" Pioneer so didn't want it to topple over.
http://www.techcraft.net/4105/detail.asp?product_id=1630
Here is the Manual and on the last page it shows how the TV is hung on the pst mount:
http://tv.manualsonline.com/manuals/mfg/tech_craft/trk50b.html?idRes=15652748
post #9788 of 12386
Thanks guys for the info' also hooking it up HDMI to a ps3. Any special settings on the ps3 I should look at? For 3D I'm setting to 96 on the tv
Turn on the TV before the PS3 so the PS3 will see the TV as a 3D device and you can set the screen size.
post #9789 of 12386
Most set their players to bitstream with the secondary audio off, to make sure you get DTS and TrueHD audio on BD. I don't have a ps3 but I'm assuming there's a secondary audio setting.
Some extra info here, the PS3 won't do 3D and TrueHD at the same time, it will do DTS Master and 3D but not TrueHD. I bought a Sony 5100 so I could get both at the same time.
post #9790 of 12386
hmmm interesting, thanks for the info.. not sure i understand about selecting screen size on the PS3? about the 3D audio, didnt know that. luckily i just have 3 films i want to view in 3d and they are all HD-MA... Dial M, Wax Museum and Creature from the Black Lagoon!
post #9791 of 12386
I hooked up an external UHF antenna to my new 55ST60 but couldn't find a channel scan operation. I switched inputs to ANT/CAB and got a box that said "run auto program in the antenna/cable setup menu". I've searched high and low and couldn't find an antenna/cable setup menu. Can anyone here give me clue please?
post #9792 of 12386
When you first connect the PS3 to a 3D TV it will come up on a screen asking you to set the screen size, that's why you need to have the TV powered on first so the PS3 will see the TV as a 3D device.
post #9793 of 12386
Set the TV on Antenna/Cable in for the input, then in the setup menu select Antenna/cable setup, then auto program.
post #9794 of 12386
Menu-Setup-set Antenna/Cable signal to Antenna, then run Auto program.
post #9795 of 12386
The weight issue is the most important factor. The size it says is irrelevant as long as the bolt pattern is the same and the TV fits and the bottom of the TV does not hit the stand.
post #9796 of 12386
New firmware update 2.727. Improve system stability.
post #9797 of 12386
So that's what "us13's peaks soft update contents." means! Thanks for translating. wink.gif
post #9798 of 12386
post #9799 of 12386
Originally Posted by CarguyHere View Post
Browser, how do you get full screen?? I get the top menu bar, but can't get rid of it.
Also, when Flash is needed, it says it has it but is disabled, how do I enable it?
Anybody know how to get full screen??
I called Panasonic, and they said turn of the Vieira banner.... that does nothing for full screen.
And the flash issue, not on the ST, only the VT.
post #9800 of 12386
Is there an "Aspect" button on the remote?
post #9801 of 12386
Hit HOME on your remote twice and select Full Screen Tv. Then hit OK.
post #9802 of 12386
When you hit home, it closes the browser.
In browser mode, you have the top banner, and the right and bottom scroll bars.. But can't "hide" them
post #9803 of 12386
i bought the Panasonic 3D glasses which have the proper on/off button. Much better
post #9804 of 12386
Brain fart. I selected the ant/cab input and then, when that screen went dark (no input), I switched back to HDMI and then went looking for the control. You have to be in ant/cable input for the selections to appear. Thanks..
post #9805 of 12386
The FW update was pretty lengthy compared to the other one I did. A good 25 minutes for me on a fairly fast connection last night but it went without a hitch though.
post #9806 of 12386
If I'm understanding you right, you hit the home button twice as recommended? Now select full screen or whatever aspect ratio you want from the format button on your Panny remote and hit ok.
post #9807 of 12386
All of my HDMI input sources are switched by my Yamaha HT receiver. When I set up my new 55ST60 the quick setup recommended I use HDMI 1. So far, everything works great except I also use a UHF antenna as a backup to my cable service. When operating the TV in antenna mode there is no audio from the TV back to my receiver although the internal TV speakers work okay. I'm a little fuzzy about ARC since my old plasma didn't have it. Should I be using HDMI 2 (with ARC) to get the TV audio back to my HT receiver? Or is ARC something entirely different?
post #9808 of 12386
I'm assuming you could also use the toslink (optical) output on the ST60 to get audio to your AVR. Admittedly I know little about ARC but this explains it well. Others will share their expertise I'm sure.
http://hdguru.com/hdmi-audio-return-channel-arc-for-your-hdtv-explained/
post #9809 of 12386
Yes! Read the labels of the hdmi ports on the set. ARC won't work unless you've got it in the right port. Think of ARC like a two way highway. Only one port supports it, the rest are one-way streets. wink.gif
post #9810 of 12386
Yes, you need to use the HDMI 2 input and you need an HDMI cable capable of ARC, it should say "with ethernet" on the cable. Then you need to turn on ARC and HDMI control on the receiver and Viera Link in the setup menus on the TV, also set the Viera Link in apps to home theater, the latter won't be accessible unless everything else is properly set and powered on.
