AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official Panasonic TC-PxxST60 Series thread
Official Panasonic TC-PxxST60 Series thread - Page 328
post #9811 of 12361
Originally Posted by sheshechic View Post
Yes! Read the labels of the hdmi ports on the set. ARC won't work unless you've got it in the right port. Think of ARC like a two way highway. Only one port supports it, the rest are one-way streets. wink.gif
I'm wondering if you sacrifice any AV quality using ARC. I know on the HDMI site they tell you everything is up to par, but has anyone verified this? So v 1.4 allows two way traffic and Ethernet, I'm just wondering at what cost and if were better off using the toslink out. This isn't scrutinizing I just want to verify.
post #9812 of 12361
Originally Posted by skman09 View Post
New firmware update 2.727. Improve system stability.
Anyone know if this has the new NetFlix update with the annoying "post-play" feature like the Roku3 has?
post #9813 of 12361
There's no difference between ARC and optical, either way it's just 0s and 1s.
post #9814 of 12361
Hi, this discussion seems to indicate there may be a difference. I guess I'll A-B it and see if I can tell a difference. I'm not doubting ARC but I don't want to sacrifice quality for convenience either.
http://www.avsforum.com/t/1446073/hdmi-arc-vs-optical-cable
post #9815 of 12361
The difference between tos and hdmi is in the equipment, not the connection, unless you seriously want to consider analog. If you're a purist, go analog for the lack of processing.
post #9816 of 12361
No I'm a digital guy biggrin.gif I just want the best connection for maximum quality smile.gif
post #9817 of 12361
I'm a bit confused.....
How would the audio return degrade video quality?? Forget the tos and enjoy one less wire
post #9818 of 12361
I was talking about the audio quality. Sorry if I wasn't clear and I'm not saying that it degrades it, I was just asking if anyone has verified that it doesn't. I don't want to go off topic so I won't post on this anymore.
post #9819 of 12361
Thanks for all the replies about the ARC port. Because I had already connected to HDMI 1 and spent thirty minutes doing the CNET settings on that port I just decided to use the TOS link. I already had a fiber link connected for my old plasma and found the audio optical port on the Panny.
So far I like this TV although there are a bunch of features I've yet to explore. I did notice something odd though. I've always had plasma TVs for their superior angle viewing. My PC is up in a loft looking down to my living room so it was easy to watch TV while working on the computer. With this TV the picture is VERY dark when looking at a down angle. I mean seriously dark like an old school LCD panel. I am now curious if it is the same looking up. Do you guys with wall mounts have a shading problem looking up? The other thing that bugs me is the side entry HDMI connections. My HDMI cable is thick and stiff and is very visible at the side of my display.
post #9820 of 12361
The filter is designed to block overhead light, and that's why the picture gets dark when viewed from above at extreme angles. The effect is much less when viewed from below.
As for cables:
Originally Posted by sawfish View Post
I posted this back in June, and it continues to work great; in particular, the cable tie hasn't popped out even once:
The AmazonBasics cables work fine, too. This is the back of my 50ST60. Each Amazon cable is connected to a bulkier, ferrite cored Monoprice 28 AWG cable with a coupler, with a total length up to 16 feet. They work great. Note also I used the supplied cable tie that plugs into a hole in the back of the case. It provides strain relief and has stayed in place as I slide the TV around my Anthrocart desk a couple times a day to get it closer and in front of the monitor arm. (I stuck plastic Super Sliders on the bottom of the stand to make it easy to slide.) The cables don't put any extra strain on the TV ports when sliding, so this has all worked out very well.
post #9821 of 12361
Can someone explain to me the reasoning to turn the pixel orbiter off during the slides, just curious.  And would running the slides even if I don't use D-Nice's settings still be a good idea?  I have the Disney Wow disc and may want to use that.  Thanks very much.
post #9822 of 12361
Unless you are getting a pro calibration and want to accumulate the required number of hours(300) faster there is no reason to run the slides. I would be conservative with settings and vary content the first 100 hours or so after that watch it and enjoy.
post #9823 of 12361
As for cables:
I think my HDMI cable is one of those over engineered Monster cables. Its about 3/8" thick and also has a big, heavy EMI choke or something right at the end. As for the shading...not really a deal breaker. Not many people watch TV from the second floor. smile.gif I noticed it mainly because my other two plasma TVs (circa 2002 and 2006) didn't do it. Glad to know there is a good reason for it, especially as I have skylights.
post #9824 of 12361
Sounds like my $4 Monoprice cables. I connect them to the AmazonBasics cables in the photo with couplers. It's all invisible from the front of the TV.
If it's any consolation, all the plasmas above the lowest tier have similar filters. The cheapest ones like the S60 lack the filter and are much more reflective.
post #9825 of 12361
Does anybody now what features were added in the new firmware update besides stability? The update took about 10 minutes, someone here said it took half an hour.
post #9826 of 12361
I'm not sure but I must have done it when the servers were over loaded because it took nearly a half hour for me.
post #9827 of 12361
It took my ST60 nearly as long to complete also,,,.much longer than the other firmware downloads.
post #9828 of 12361
Originally Posted by chunon View Post
Home screen collection
http://shop.panasonic.com/shop/model/TC-P55ST60?t=downloads&support#tabs
That is the older version of firmware, not the newest which was just released yesterday or today; not sure of the version number since I've not applied it yet.
Newest firmware is said to be 2.727 which I've not applied yet.
Edited by Bob_Collins - 12/3/13 at 12:25pm
post #9829 of 12361
I'm impressed with the glitch free and what appears to be routine FW updates. No big issues for me at all, although I'm sure there were some needed updates. I think we've all heard about ones that don't go nearly this smoothly.
post #9830 of 12361
Guess I missed that one thanks for the heads up
Edited by chunon - 12/3/13 at 12:11pm
post #9831 of 12361
If you don't use any of the smart/internet/3d features is there any reason to download the firmware updates?
post #9832 of 12361
This last update just says System Stability improvements, that is kind of vague. But it is probably related to smart features of some kind. Short answer probably don't need to worry about it unless we get specific information that it improves pq in some way.
post #9833 of 12361
Tv delivered. I have no idea even wgere to start with settings and such. Can someone link the CNET settings as I would like to try them until I break this in for 100 hours and maybe then try D-Nice
post #9834 of 12361
Should the "1080p pixel direct" option be on or off for 24p Blu-ray?
post #9835 of 12361
It should be off from what I have read causes false contouring
post #9836 of 12361
That's what I figured but wanted to double check. Thanks.
Google the cnet review, about 3/4's of the way down is a link to the settings they used. I think d-nice has his own recommendations though for when running the slides.
post #9837 of 12361
Thanks. I checked the review but I don't see a link on their review. Maybe I am missing something. I found some settings in a forum on cnet.
http://forums.cnet.com/7723-19410_102-590736/panasonic-tc-p55st60-picture-settings/
post #9838 of 12361
FWIW and AFAIC, there is no shortcut to break in, I personally like DNice's slides @ Custom default settings (that's 100% contrast) for at least 100 hours (I did 300). BTW, CNET had 150 hours on their ST60 before they did their calibration. smile.gif
post #9839 of 12361
Originally Posted by srg914 View Post
Any recommendations for a break-in (slides) disc?  Am new to the world of plasma...thx.
Full-screen content with no static logos (semi-transparent is okay after a while). Something like colorful movies, PIXAR movies, etc. You can loop movies, or load up a PS3 or something with videos/trailers and let it loop. I I personally watched normal TV/movie content, and when I wasn't using it for that, I'd loop video game trailers on my PS3, for the first 100~ hours. Enjoy your TV, don't worry too much about break-in, except for being careful not to get any IR. smile.gif
post #9840 of 12361
Hi Robin, did you try Cnets settings? I didn't but I looked them over and was kind of shocked with the zero brightness and sharpness settings. I'm trying to get to 300 hours before I run the Spear and Munsil disc.
