AVS › AVS Forum › Video Components › Video Download Services & Hardware › Netflix adds 3D and Super HD
Netflix adds 3D and Super HD - Page 37
post #1081 of 1798
I'm seeing UnoDNS go to the SuperHD streams but it is much, much slower for me than it was with unBlock US. It's taking over 30 seconds to get to the 5800kbps stream in the example short. While with UNBlock US it would only take a few seconds.
So far I've tried four 3D streams and they started without issue.
post #1082 of 1798
Toronto seems to be the only one that is Dynamic Enabled - http://www.unotelly.com/quickstart2/dynamo.php
As far as I can tell that allows different devices to select different regions.
I set up mine using the 2 California DNS for now - seems to be connecting to the Netflix Open Connect servers OK.
Edit - actually if you look at the list (not the map) all the north american one are Dynamic except LA. I changed LA to East Coast and now can access the UnoDNS Dynamo Settings.
Edit - yes it seems to take about 30 seconds to get to 5800 kbps - however for me unblock-us was about the same if it connected at all. Roku 2 XS on a 16 mbps Comcast connection.
Edited by undecided - 4/15/13 at 5:32pm
post #1083 of 1798
From these comments it sounds awfully complicated. Given that my ISP is set up for OC access I don't need one of these services for Super HD in the US region and I always get OC servers using Unblock to any other regions so I think that I'll just stick with them. I may give them a quick try, given the free 8 days.
post #1084 of 1798
It's no more complicated than Unblock-US. Just find the server closest to you, plug in the numbers in your router and you're all set.
post #1085 of 1798
There one complication right there that Unblock-US doesn't have--no finding the server closest to you.
Does the service offer any real advantage for people who have access to Open Connect in the US through their ISPs?
post #1086 of 1798
I dunno, doesn't seem that hard to me, just look at the map, choose, plug in the numbers, away you go.
As far as offering any advantages, well, you'll have to decide. It offers the same amount of other region Netflix offerings as Unblock, and various other services. You'll have to take a look at it and decide.
post #1087 of 1798
They claim 'Dynamo allows you to have different version of Netflix simultaneously on different devices! So you can have one device playing UK Netflix and another playing US Netflix. I haven't tried it but could see our household using that. It also seems you can run BBC iPlayer from a WDLive in the US (though sadly not a Roku).
post #1088 of 1798
Interesting, but I've got no use for that. I do wonder how they do it. Given that all your devices are on routers on the same modems, they'd all have the same external IP address--how can they tell the difference between them?
I wonder how you'd get iPlayer installed on a US TV Live?
post #1089 of 1798
I haven't tried it yet but here is the claim 'For example, you are living in Canada and want to watch UK Netflix on your iPad. However, your wife might want to watch some US Netflix. If you are using comeptitor's product, you are stuck with Netlfix UK. With Dynamo, you simply set your iPad to Dynamo DNS, choose the UK as the Netflix country. Meanwhile, your wife's device can be normal UnoDNS server. Voila, now you are playing different countries of Netflix at once without interference. How cool is that!'
Instructions here http://help.unotelly.com/support/solutions/articles/63462-how-to-add-huluplus-or-bbc-to-your-wdtv
Again I haven't tried it (because I have a Roku not a WDLive)
post #1090 of 1798
UnoDNS works 100% of the time from the US to the US SuperHD servers for me so I guess I'm going to switch.
Thanks for pointing this out Mr. G!
How are checking you get the US SuperHD servers?
If I use the 'example short' it always connects and goes to 5800 kbps - yet when I play actual titles the realtime bandwidth I see on my router is less than I would expect for 5800 (video) + 384 (audio) SuperHD encodes. It varies quite a bit which probably makes sense for adaptive streaming. What average realtime bandwidth are people seeing with ISPs that support Open Connect on SuperHD tiltes.
post #1091 of 1798
I tried it a while ago....just wasnt practical enough for me, not over Unblock. If someone wants to watch different regions simultaneously then you would have a desire for it.
post #1092 of 1798
I've checked by using my router. In Tomato I'd go to QoS->View Details, check "Automatically Resolve Addresses" at the bottom of the page and click the Source heading to sort by device. I've done this from a browser on my tablet while viewing content on various devices.
post #1093 of 1798
So far my experience with UnoDNS has been less than ideal. Initially it seemed fine but when I tried it some more later last night, I had some times that the streams stayed at 480P for over a minute and one time never exceeded SD. With UnBlock US, it may have been inconsistent getting SUperHD but at least it still ramped up to the 3800kbps stream quickly even when it didn't get a SuperHD stream. I did change my IP address from FiOS a couple of times and noticed a difference with the different IP addresses. But each time I went back to the FiOS DNS addresses, everything also ramped up to the 3800kbps stream quickly. While with the Uno DNS IP addresses were inconsistent.
post #1094 of 1798
Seems to work OK for me. Takes only a min or two at most to ramp up to SuperHD.
I did a traceroute to find the server with the shortest number of hops and used that one. Could also be because I have a 75/35 connection.
post #1095 of 1798
I've got a 150/65 connection. I only have the issues with slow ramp up when using the UnoDNS IP address. Although this morning it was working better.
post #1096 of 1798
UnoDNS appears to have issues as well. If you want to get a SuperHD connection on some streams you need to first connect to a stream you know has a SuperHD connection (like the 23FPS test clip), then it should work fine. Still easier than backing out all the time than with Unblock-US.
Also, I can't seem to get SuperHD streams on PC at all, just on dedicated devices (PS3, BDT220, etc). So if you plan on watching with your PC, this isn't the best route.
post #1097 of 1798
On the Comcast forums, somebody says they do have Open Connect on their Comcast Business?
http://forums.comcast.com/t5/General-Hardware-and-Software/Netflix-Open-Connect/m-p/1662701#M13814
post #1098 of 1798
That's interesting, I wonder if they are using a DNS re-director.
post #1099 of 1798
Originally Posted by mdavej View Post
I've tried Charter, and it doesn't work.
Charter cable company in Madison, WI has a working Super HD connection. I guess they've crossed over. I'm visiting my daughter in Madison today and for curiosity's sakes checked her connection. She has 30 Mbps download speeds. I checked with Netflix Super HD for confirmation then tried her WDTV Live streamer since I can see the ramp up speed and resolution as it does so. The Grey got to 1080 HD in 35 seconds, Haywire took 21 seconds and Limitless took 13 seconds to get to 1080 HD - all with DD+ 5.1.
post #1100 of 1798
They posted a reply:
I can confirm I have gotten super HD via my Tivo Premier DVR. I can see a major quality difference from regular Netflix HD. 3D works too.
I roll my own Internal DNS server and am behind a sonicwall. The DNS server connects to OpenDNS for external zones.
Whats interesting is that at my office 3 miles away from my home (which is also comcast business class) says I don't get Super HD. the network setup is indentical too.
post #1101 of 1798
Saw that, thanks. Still confusing though as to why he is getting that connection, can't imagine it has anything to do with it being a business account.
post #1102 of 1798
Still why the three biggest providers (Comcast, FiOS & TWC) can't do SuperHD yet some small known ISP can do it? What they rather you use there crappy streaming service.
post #1103 of 1798
I don't know how they stack up as ISPs, but FiOS finished the year at 4th in basic cable subs, though neck and neck with Cox, who are third place (then AT&T, Charter, Cablevision). Cox is set up for Open Connect so they do have one of the top three MSOs. However, Comcast with 22M subs and TWC with 12.4M are way ahead of the pack, given Cox's 34d place 4.6M.
Between Cox, Cablevision and Suddenlink, about 9M basic subs have available access to Open Connect; Charter would give them another 4M. Who knows how many total subs the tiny little local systems they have signed up represent.
Edited by michaeltscott - 4/18/13 at 12:00pm
post #1104 of 1798
It's not the size of the big ISP's, but the reluctance of them to wave their CDN fees. You don't have to be small to be cheap.
post #1105 of 1798
As has been pointed out elsewhere, we don't know what Netflix is asking--no one has disclosed that. If they pay the same as the other CDNs they still improve their bottom line by not paying them enough for a profit on top of that.
post #1106 of 1798
As I recall, it's not what Netflix is asking, but that the cablecos will lose the money they charge the current CDNs that are delivering Netflix content to the cablecos network, Netflix wants to avoid having to pay those current CDNs(which in turn pay the cableco) and deliver the content straight to the cableco themselves, but Netflix wants to do this without paying, it appears to be anyway.
post #1107 of 1798
I don't think it's just about the money. It's how they run their marketing infrastructure. I believe there is a conception that Netflix is the competition and can potentially draw business away from them. Services such as HBO and Showtime are becoming Netflix's biggest target and these networks are revenue streams for the ISP's. They're just not ready to jump on the proverbial Netflix bandwagon, so to speak.
Ian
Edited by mailiang - 4/18/13 at 9:21pm
post #1108 of 1798
...but Netflix wants to do this without paying, it appears to be anyway.
That's a huge and unreasonable assumption. No one has ever said that and if it were true I'd expect it to have been pointed out: "We haven't signed up for Open Connect because Netflix is asking us to lose money on the deal". Why would large national MSOs like Cox and Cablevision be willing to accept a cut to their bottom line? I don't buy it.
post #1109 of 1798
It's definitely an assumption, but I'm not sure they would make something like that public, these companies are pros at obfuscating the real issues and concerns, especially when it comes to money.
I'm not pro or con either side here and it could simply be a matter of time to install the equipment required, a company like Comcast would certainly take awhile as huge as they are.
OTOH, Comcast claims "billions and billions" of streaming/VOD views of their content and that's a lot of ad revenue that would shrink if users move over to Netflix.
There is too much about this that is unknown, which most often means disputes over money.
post #1110 of 1798
They wouldn't disclose it in fine detail, but if it were true simply saying, "We're not signing up for Open Connect because it loses us money, pure and simple. We'd love to do it if the terms were better, but as is we'd have to raise our service rates". Deflects blame, makes Netflix look bad. I find it a lot easier to believe that the big MSOs are just disinclined to do anything specifically to improve Netflix's service. If their network service subs want to watch Netflix there's nothing that they can do about that but they have little incentive to improve the quality of the product and any advantages of using Open Connect aren't enough to compensate. Who knows? They may actually have some financial interest in the other commercial CDNs.
It may only be taking a while for them to come to agreement on terms or for them to implement Open Connect access system wide before launching it. Netflix has been peddling it for nearly a year and systems are still slowly coming on board.
My housemate/landlord got the account info of a friend who lives in another city with a Comcast system and watches Xfinity on his iPad. He really loves it. TWC now has a streaming service with a channel available for 2nd and 3rd gen Roku.
