Originally Posted by michaeltscott
As for HD video disc bit rates, those vary a great deal as well. I see Harry Potter and the Goblet of Fire was encoded at 12.8 Mbps and Troy at 11.7 Mbps--both got 4.5 of 5 stars for video quality in their High-Def Digest reviews. I'm certain that there are titles encoded to BD at higher bit rates with terrible PQ. In short, bit rate does not equal picture quality.
I know what you are trying to say but if you bit starve a encode it will show. Give it enough bits and the artifacts go away and I think that is the reason most folks think more bits = better picture and in the general sense is true.
I would not compare Blu-ray bit rates with Netflix bit rates. The encoding of a BD is a multi pass process and the coder can flag areas that would require human input to fine tune. I would wager that Netflix (and probably most other IPTV providers) use a automated, one pass, coding of their titles and doubt very seriously they manually QC the end results like they do for a BD.
Do you know of a single BD title with high bit rates that has terrible PQ and you can attribute that PQ to the bit rates?
For readers: do not confuse video data reduction (compression) with transfer and mastering, they are completely two different processes. That old saying of garbage in = garbage out still applies. IOW, if you source master is sub par you could do a perfect encode but the end result is still sub par.
