AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Which Receiver to use for a processor?
post #1 of 9
It seems like the current crop of budget processors may be plagued with problems again...I am thinking of just using a receiver to decode to my power amps...I was looking at the current crop of receivers with pre outs....I'd like to stay at 500$ max...It can be new, used or refurb, but have all of the latest surround lossless formats...Anyone have any experience with the Yamaha Adventege receivers? What other choices are out there? Thanks!
post #2 of 9
I am using refurb Marantz SR5007 as a processor. Bought refrub with 1 year factory warranty..
post #3 of 9
Everyone will tell you how reliable Yamaha is but I've had mine and 3 friends all had theirs malfunction.
I would buy Yamaha again but for now I went to Onkyo, who many will say have major quality control issues.
I wouldn't hesitate to go with the Yamaha Aventage line or the Onkyo 609 or 809 which is pushing your budget however.
post #4 of 9
Would this be a good choice over the Yamaha for 200.00 more? PS Im using a 10 year Atlantic Technology processor now so anything will be a big step up! http://www.accessories4less.com/make-a-store/item/MARSR5006/Marantz-SR5006-AV-Receiver-with-Networking-and-AirPlay/1.html
post #5 of 9
Anyone know the diff between these two? Or would the marantz be a better choice? I only care about the processer portion of them! http://www.accessories4less.com/make-a-store/item/ONKTXNR717/Onkyo-TX-NR717-7.2-Ch-THX-Certified-Network-A/V-Receiver/1.html http://www.accessories4less.com/make-a-store/item/ONKTXNR709/Onkyo-TX-NR709-7.2-Channel-3-D-Ready-Network-A/V-Receiver/1.html
Edited by alan_ct - 1/8/13 at 2:01pm
post #6 of 9
Unless there's some extremely esoteric feature differences someone wants to point out, the NR709 and SR5006 look to pretty much neck-and-neck feature wise. Both have all the modern audio codec support, HDMI 1.4 for 3D and ARC, PLIIz and DSX for height/wide channels, MultEQ XT room correction, etc. The Marantz has AirPlay for streaming audio from iOS devices which the Onkyo lacks. Both have learning remotes, but the Onkyo remote also supports basic macros/activities.
The NR709 would probably be my choice for a an AVR-as-Pre/Pro these days, unless you want to spend $250 more for the NR818 to get MultEQ XT32 room correction, and the main benefit there is more EQ points when running dual subwoofers. It's a shame that the newer NR717 drops the room correction all the way down to 2EQ, making it much less compelling as a Pre-Pro.
post #7 of 9
I don't think you'll find anything new for $500. I know I couldn't find anything.
An Aventage refurb (A800) is what I went with. It's only been a month, but I am thrilled so far. Adventage refurbs come with 2 year warranty (according to OneCall).
post #8 of 9
Thanks...Do you think the processors are similar in the RX series receivers?
post #9 of 9
My previous receivers were RXs. I don't hear a significant sound difference between them and the Adventage. The Adventage is more about features (like the pre-outs) and build quality (50% longer warranty).
