AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official Sony BDP-S1100, BDP-S3100, BDP-S4100 and BDP-S5100
Official Sony BDP-S1100, BDP-S3100, BDP-S4100 and BDP-S5100 - Page 22
post #631 of 2898
Originally Posted by Foxbat121 View Post
3D adds nothing to the movie story line but headache for me. The limited viewing angle and the weird looking glasses just not my cup of tea. ..........,
This is one of the reasons I like my active glasses over the passive ones. With my DLP set I can get ultra close to the TV or look at it from a wide angle and there are no issues with the 3D. Unlike with the Passive 3D set I also have. Without 3D I would not have purchased most of the BD titles I did this year. WHich the S5100 also does a great job with.
post #632 of 2898
Originally Posted by andy sullivan View Post
I don't see any AVR's listed at Costco. I even typed in Pioneer SC-1522. Nothing. Unless they are not available on-line.
See -> http://www.avsforum.com/t/1464476/pioneer-sc-1522k-for-599-99-at-costco
post #633 of 2898
I have a 3D plasma TV and active glass as well. It should have the best viewing angle than LCD/LED or DLP but hornestly, it's just OK. I certainly won't pay extra for 3D.
post #634 of 2898
Hi Guys,
I want to buy a Blu-Ray player which has to have wifi connectivity, 3D capable and has to play SACD s. One of my friend suggested Sony BDP-S5100 Blu-Ray but i dont trust that noob :P So need your advice. If there is any at same price range that you can suggest over this one please share your ideas, all ideas will be appreciated.
post #635 of 2898
Originally Posted by codeihk View Post
Hi Guys,
The S5100 will be fine for your needs. SACD limits your choices at the $120 price barrier.
post #636 of 2898
I have a Sony BX1 (Costco model of BDP-S350).
Besides 3D and Smart features, would there be any other reasons to upgrade to the 5100, such as differences in PQ?
post #637 of 2898
I had a BX1 and recently bought an S5100 (actually BX510, the Sams version), and there are improvements to PQ visible in certain patterns on Spears and Munsil 2nd at least. (Sorry, I don't remember the details, and in practice, they're probably pretty minor.) The big reason to upgrade is the hugely faster speed of all disc operations, from the tray to loading content to chapter skipping and so forth. I basically stopped using my BX1 because it was so ridiculously slow at everything. It was painful to use it. The BX510 actually makes Bluray sort of viable. On the downside, the fanless BX510 is much noisier than the BX1 with both its drive and fan going, and it's a much more annoying noise, a high-pitched whine at just about all rotational speeds. The construction of the BX510 is cheap plastic junk compared to the metally BX1, and some units vibrate throughout the whole case. I went through four samples, two from Amazon and two from Sams, hoping to find a quiet one, but I had no luck. They were all about the same. Ditto for Samsung's cheap plastic junk equivalents like the F5900. The Samsung also enhances its video output, such that one needs to change it from its "Standard" Picture Mode to "Movie" to get output consistent with the Sony and other devices, and even then it's a little juiced. The one advantage the Samsung had was a usable subtitles feature. The stupid, stupid Sony can only cycle through subtitles making the feature useless as many discs have a dozen different subtitle languages, and you can't just turn the one language you need on and off. I can't believe Sony hasn't addressed this.
Keep your BX1 remote. The sawn-off S5100/BX510 remote doesn't come with Skip Forward/Back buttons, but the ones on the BX1 remote work. If you use that feature, you could just use the BX1 remote or teach it to a universal remote.
post #638 of 2898
That is crazy about the subtitles. Anyway thanks for addressing my question! I only wish I had gotten a BDP-S590 when they were super cheap and have great reviews. Hopefully the 5100 will be just as good in time.
post #639 of 2898
Originally Posted by Kisakuku View Post
I just noticed that SACD iso's burnt to DVD-R that played fine in S590 are not recognized by S5100. Can anybody verify this?
Re-checked the same DVD-Rs in S590, where they had worked before, and they are no longer recognized either. I guess this is some issue with the media, can't blame S5100 any longer.
post #640 of 2898
Got a BX510 and for some bizarre reason cannot perform a network update. Instead I get the "Connection status cannot be confirmed" error message. Every single other network service works fine: Pandora, Netflix, YouTube, DLNA, etc. The BDP is connected through a Powerline bridge, no WiFi. No errors in network diagnostics, IP is assigned through a DHCP reservation. My BX58 and BX59 were connected at the same location and never had this issue.
I guess I could just burn the firmware update CD, but that would be admitting defeat...
Even more bizarrely, this turned out to be an as-yet-unidentified router issue. Although placing S5100 in DMZ still results in "Connection status cannot be confirmed" error message, plugging the BDP directly into my IP-DSLAM modem allows it to perform a firmware update. I guess this is easier to do than burning firmware update discs.
post #641 of 2898
I noticed today at Target when I looked at the back of the S5100 display unit they had that it didnt have a Digital port only Coaxial. I guess Sony has done away with that option on their 2013 Blu ray players? It seems everything is going HDMI only. I like the look of the player and might have to replace my S590 with it.
post #642 of 2898
Both coax and optical carry the same S/PDIF signal. This year, Sony lacks optical, while Samsung lacks coax on the comparable model. For someone who has to use one of these ports, and with TVs almost exclusively providing only optical out for use with AVRs, one could argue that Sony made the better choice. Those who find it the wrong choice can buy a converter, $10 or so at Monoprice.
post #643 of 2898
Those old legacy connections will probably be history soon.
post #644 of 2898
And as what I can only assume is an unintended side effect of the latest firmware, my S5100 no longer plays SRT subtitles embedded into MKVs either from USB or DLNA. If no subtitles are present, I still get the usual error popup, but if subtitles are embedded, no "on" or "off" overlay comes on and no subtitles are displayed. S590 plays the same MKVs with subtitles without any issues.
post #645 of 2898
Manually changing DNS setting on the Sony BDP-S3100
Just wondering if this can be manually changed? Anyone that can provide assistance, it would be much appreciated.
post #646 of 2898
Welcome to AVS. Mods ask that all posts go in the official player thread. Please reask there.
http://www.avsforum.com/t/1450585/official-sony-bdp-s1100-bdp-s3100-and-bdp-s5100
S~
post #647 of 2898
Double checked everything, can't figure it out. The only thing that's different is the firmware upgrade from M15.R.0095 to M15.R.0121. Could somebody who had flashed .121 please try playing an MKV with embedded SRT subs and report back?
post #648 of 2898
Don't know if you figured this out yet, but the muxing of the BD audio with the other audio necessitates conversion to PCM so it needs to be turned off if you want to pass the DTS encoded audio
Settings > Audio Settings > BD Audio MIX Settings > OFF
Settings > Audio Settings > Digital Audio Output > Auto
post #649 of 2898
Not sure how this relates to my question, or did you mean to quote an earlier post?
post #650 of 2898
Well, this certainly seems new:
Subtitle (.srt file format) is not supported by the Digital Living Network Alliance® server (DLNA) hence will not be displayed when streaming videos.
Still doesn't explain why SRT subs stopped working for MKVs on USB storage.
post #651 of 2898
Seeking to see if anyone can assist with manually changing the DNS Settings on the Sony BDP-S3100 blu ray player?
post #652 of 2898
post #653 of 2898
Go to network settings and select custom IP address. There you manually put in all the information (static IP address, gateway and DNS). Or if you have a capable router, simply setup the router to use custom DNS.
post #654 of 2898
I'm considering buying the s3100 as I'm not interested in 3D. Is the processor on the 3100 the same as the 5100? I've heard that the 3D models have a more powerful CPU which also results in better performance when viewing 2D material. Can someone please confirm this? If it is the case that the 5100 has a better CPU than the 3100, is it worth getting it just for that reason?
Also, do these players have a 'pass thru' i.e. raw bitstream for audio or is audio always coverted to PCM?
Edited by abuhafsa - 5/31/13 at 10:34am
post #655 of 2898
There both the same and you won't notice any performance difference. Both players can output bitstream subject to the receiver be able to decode it.
post #656 of 2898
so what formats do subtitles need to be in for streaming via DLNA?
post #657 of 2898
Does anyone finding the YouTube app sign in very annoying? I need to re-sign in almost every day.
post #658 of 2898
Thanks for the reply. I picked up an open box 3100 for $85 at BB this afternoon. Watched Contact and Hunger Games on amazon instant and was impressed with the streaming video and audio quality. Tested both video and audio with the Disney Wow BD (hooked to a Denon 591 receiver). So far so good. The disc playback is a little noisy when starting up and skipping chapters but quieter during 'normal' playback than the LG BD570 I had previously.
I noticed the parental controls had something about 'scenes getting blocked or replaced'. Has someone tried this? What does it actually do and what do the levels mean?
post #659 of 2898
I never have to re-sign in.
post #660 of 2898
I was thinking of getting the BDPS5100, to replace my Pioneer BDP 140. I've got a couple of questions for those who have the unit. How does it perform as a cd player? Is there noise from the drive? Does it decode HDCD? Does it display cd or flac album art on the TV screen? Thanks
