AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official Sony BDP-S1100, BDP-S3100, BDP-S4100 and BDP-S5100
Official Sony BDP-S1100, BDP-S3100, BDP-S4100 and BDP-S5100 - Page 31
post #901 of 2898
IR blasters usually bast IR, not plug in. If you place it anywhere in front of the player it will work fine. You have to get a high end player if you want an IR input jack. You can also control it over wifi with a smartphone app.
post #902 of 2898
Originally Posted by Foxbat121 View Post
The limitation is system wide for Netflix regardless of the players. Roku won't get any special treatment either. This change is quite recent. I'm not sure how old is your Roku impression.
Roku only outputs RGB and always enforce noise reduction. As such I've found the picture quality to be softer than other players including Sony BDPs
post #903 of 2898
Hi all, I recently purchased the S5100, and so far I love how it compares with the Panasonic BDP-220 that I returned because I hated its menu structure, remote, subtitle selection process, and superloud spinning with DVDs.
However, the 2 movies I played this weekend had a bit of the "Soap Opera" look to them, which was certainly not the case on the Panasonic, and it drives me nuts. I remember that effect is related to motion blur reduction etc, and I am not sure if there is a standard setting that I am able to change. Has anyone else had this issue? Am I missing something obvious?
post #904 of 2898
Does anyone know if AT&T U-Verse supports the Super HD from Netflix yet?
Also, will a Kindle Fire HD be able to throw on the 5100? Would I browse the internet on the Kindle and throw it or on the 5100 itself?
post #905 of 2898
Originally Posted by uzun View Post
I bought a 5100 to replace a 590 I had in my home theater room, I wanted to move the 590 to a different room to have internet video services there. The 590 gets VIMEO, and the sony website indicates VIMEO is supported on the 5100 but I dont see VIMEO on the list of internet video providers. It did update the ROM and Youtube, etc all work fine.
Is there some reason the 5100 would lack VIMEO when the 590 has it?
-Roger
Its there.
Just go to the Opera TV Store and install the app.
post #906 of 2898
I don't think the player does any motion interpolation. Does your TV have per-input settings that may need to be disabled or altered? On my Sony, it's a combination of MotionFlow and CineMotion settings that enable it. You can turn MotionFlow ON, but if CineMotion is OFF or Auto2, it will only duplicate frames, and not interpolate new ones. CineMotion Auto1 enables that (yuck.)
post #907 of 2898
There are no inputs at all. If they're both on the same network you can view some vids, pics, etc. U-Verse did not have open connect the last time someone reported it.
post #908 of 2898
Originally Posted by TheChadd View Post
Spent 30 minutes in chat with Sony support. They ran me through every permutation of update and reset on the damn thing. Of course none of that worked. No mention of ISP issues. They are escalating and will email me, I guess. News at 11...
Well, I never got that email Sony said they were going to send me with escalated support for missing Netflix/Amazon/Pandora icons. I guess I just have to keep chatting with Tier1 support and hope for the best. It's been more than 2 weeks since purchase, so I can't just return it anymore :/
post #909 of 2898
Most retailers offer a 30 day exchange/return policy. Where did you purchase it from?
post #910 of 2898
Thanks. How is the DLNA on the 5100?
post #911 of 2898
I have had the s3100 for about a month. Trying to program my Sony STR-DN1030 remote to control the s3100. I tried the 3 codes in that manual - 310,311, 312 and no luck. Does anyone know the code? Thanks. I couldn't find it on the Sony site either.
post #912 of 2898
Try again. 310 should do it.
post #913 of 2898
Ok. Thank you. I will try again.
post #914 of 2898
Does anyone know if blu-ray player 5100 or 790 can recognise AVCHD folder like a blu-ray disk?
I own 780, I tried on usb, if u put there a copy of ur blu-ray disk files in a folder named AVCHD, it recognise ur movie from external hard disk or flash, but when I tried with DLNA not regnise that, can anyone tell me if this working on last models 5100 or 790?
thank you.
post #915 of 2898
Best Buy. I think it is only 15 days with them.
post #916 of 2898
It's been a while since I purchased anything from Best Buy, thanks for the info.
post #917 of 2898
Originally Posted by Led Zappa View Post
My old BD player died and I got a Sony BDP-S5100 Blu-Ray player now and I can't get my 3311 to play DTS-HD. The players display says it's 5.1, but my 3311 just says BD/STEREO. Nothing is coming out of my rear speakers. Tried Caddyshack and T2 and Star Trek True-HD. Any ideas?
My Receiver says:
Surround Mode: STEREO
Signal: Dolby TrueHD
fs: 48khz
Formate: 3/2/.1
try turning off bd audio mix in settings.
post #918 of 2898
Thanks for trying to help. It was my receiver. Don't even know what I did to fix it lol. When your in the menu you can't see what the receiver is outputting, but when I exited after changing a few things I thought I changed before it was outputting correctly.
post #919 of 2898
Sure NP. There were 2 settings to fix the same issue for me. One was the BD Audio Mix in the bdp and the other was in my AVR (different than yours) - The HDMI - from TV + AMP to just AMP. Glad you figured it out!!
post #920 of 2898
And just like magic, I saw a new icon saying there is updated content available. I clicked on that, and voila, Netflix and Amazon reappeared. Glad this problem is over with.
post #921 of 2898
Sixty days with Silver Reward Zone. I purchased my second S5100 from BestBuy and was able to get a price match thirty or forty days after purchase because of the sixty day return policy.
post #922 of 2898
I use blu ray players only for BDs and DVDs. When I saw the picture quality of this machine, I replaced my S790 with it. All of my Blu Rays looked better than ever and the DVDs were equally as great. These players have triluminous color.
The S790 does not. Looking at the 4K mastered Blu Rays was even better. I brought two more for my other rooms. I purchased the machines at Cosco for $109.99.
Here is a review: http://www.whathifi.com/review/sony-bdp-s5100
Edited by HDPERSON - 7/5/13 at 11:57am
post #923 of 2898
It seems odd that the new Sony 70R550A has a optical connection yet the 5100 only has a coax connection.
post #924 of 2898
They wouldn't connect to each other anyway, you know. I figure they did that because AVRs have been sharply cutting back on the number of S/PDIF inputs, and there may not be more than one optical and one coax.
post #925 of 2898
They do sell converters for about $11 for coax to optical or optical to coax.
post #926 of 2898
A friend of mine has their non smart Sony TV connected to their Sony 3100 blu-ray player. I'm not sure how it's connected though.
post #927 of 2898
"Smartness" or the lack thereof doesn't imply anything here. For what we were talking about, the TV and BD player have digital outputs, and connecting two outputs together would make no sense. For your post to be a counter-example, your friend's TV would have to have (a) HDMI or more likely DVI for video, and (b) a digital audio input.
post #928 of 2898
thank you.
I've played both Bluray and DVD+R discs with AVCHD on the S5100 and they worked fine. Haven't tried it with an external or flash drive, though.
post #929 of 2898
Hi all. I just got a 5100 player the other day and was drying out the DLNA streaming of it. When I first set it up, it was able to see the MP4 files on my DLNA server ( tversity) and although it is not able to play all of them, it can play most of them. But today, when I tried going to the same MP4 files, the player is now reporting "no playable files found". I did not change any settings on both the server and the player side at all. Is there a setting where you make it show all the files, not just supported files ? Any advice would be welcome. Thanks
post #930 of 2898
Any chance of Sony releasing firmware that enables album art for flac and sacd files. Cd's dial out to gracenotes so why don't sacd discs? Anyone know of any workarounds?
