Why? I'm all for overkill but that is just a waste.
Originally Posted by beastaudio
I got the 3/4" pine for my last build, had a nice solid void running right through it from side to side. Didn't notice until I had the drivers installed and they were in the theater, then had to damage control repair the holes by using REAL silicone to seal it back up. Now THAT stuff is nasty. wood looked lovely, but was basically crap. Inspect each sheet you get VERY carefully
That is the problem I kept running into, hence just deciding on going with MDF. It will take 2 or 3 of us to move the finished cab into place, but I know it's solid.
