AVS › AVS Forum › Audio › Speakers › Pioneer FS51upgrade to Infinity P363
post #1 of 6
Right now, I am using the Pioneer FS51.
I find the Infinity P363 is on sale with a very reasonable price.
Do you think it will be an obvious improvement? or are these two speakers are in the same level?
BTW, Is there any good suggestion on how to improve the speaker?
Edited by BTTOG - 1/9/13 at 1:03pm
post #2 of 6
Its a diiferent sound. You might even like the new FS-52 My local Fry's has both in same sound room along with several Polk models.
I actually like the way the FS-52's sound.
The P363 has a higher senitivity than your FS-51 so it'll sound louder at the same volume.
post #3 of 6
Might sound better depending on your taste...but that would be a lateral move and not an upgrade!
post #4 of 6
well, I just feel the Pioneer FS51 is too flat. the sound is warm, but not exciting.
If I change a more powerful receiver, is there any big change?
post #5 of 6
No. The widest range of sound available is - was - and always will be - speakers. If you were to consider changing to all tube electronics that would be a game changer.
post #6 of 6
thanks. any advice on how to update my speakers?
  Back to Forum: Speakers
