Originally Posted by mlknez
I just left the ces show floor for the day. The processor is an unannounced Intel media processor not a CE proc.
Native is source direct
Looks like summertime availability.
The folks in the Dune booth know about this thread and are watching it.
This is not an HTPC. What do you want a picture of?
How is it not an HTPC you are running 4gb of ram, an intel cpu, you already said its running xbmc, and already said its running mplayer for audio, everything about it screams HTPC and not a custom player/software. I could go put xbmc on my i3 box I just built for 350$ I will set external audio player to mplayer and it would function exactly how you described it, I will install powerdvd to give me my full iso support with cinavia, again how its described above and i will tell single file to play in mplayer and avoid cinavia on them
We need to know what is pushing the video is it straight software decode on the intel again HTPC is it GPU driven and if so what GPU is it using, Everything about it down to the details you gave sound just like a functioning HTPC setup, And again there is nothing wrong with that, If they found a way to bridge the gap and clean it up to where you dont have to pick external players then its a valuable option to consider.
And when you said intel Media all that says is its using the linux media sdk to push video to the hardware decoder being the current at HD Graphics 4000 on the recent intel models,
The interesting part being is the FULL bluray playback cinavia or not as to date there has been no free or pay option for it on linux and as far as i understand Bluray specs do not allow it because linux does not have the same secure channels as windows to output the video over hdmi , and the screenshot clearly shows its running on linux
