Originally Posted by Mr Eric
coming back on my speculation about the chipset here : http://www.avsforum.com/t/1450642/dune-max-hd-3d-at-ces/30#post_22809481
I thought that they were using a Bay Trail chipset that was just annouced this week because they said it was an "unannounced chipset". But in fact my first thought was correct...
they are using a BerryVille chipset CE5315 that was annouced in Q1 2012. Confirmation here : http://www.hdlandforum.fr/viewtopic.php?f=25&t=1702
CE5315 is the lowest end of the CE53xx chipsets, with only 1.2Ghz and no PQE. Apparently the Max 3D will have 2GB ram. It should also include a SGX 545 GPU which is quite old (2010 according to wikipedia) but should be enough for xbmc to run smoothly.
That will also explain that the video is showing "exclusive to Max 3D and Pro", so the the Pro might be back from the dead as well.
Now that they found out a solution to ditch Cinavia and play 3D and full menus from both discs and files, they can perfectly use an upper chipset (CE5348 for example) from the same chipset family, just add some high end components + NAS/Server functions (easy with intel chipset) and here you will have a new Pro...
Thanks for the updated information, So this kinda rules out 10bit anime files as the doubt the 1.2Ghz ce line is fast enough for it by itself, I have been looking for something that works with anime files but nothing good yet, Wonder if intel finally fixed the HD audio issue that boxee had, will be interesting to see how it performs when it comes to light, Strangely I thought Intel abandoned the whole CE line,
