So I was talking in earnest about doing one of these with a professional installer, and he talked about how they drill hundreds of tiny holes in the ceiling from the attic to run the little fiber optic wires, making a beautiful starlight ceiling at the mere cost of 8k for an 8x12 area... When I came to, I had a much simpler, and cheaper idea you could do yourself, I might be talking out my rear here, so thats why I'm bouncing it off you guys.
Make a big frame of the area to light(say, 8x12), with a solid backing. Paint the backing black, attack the backing to the ceiling. Run the tiny fiber optic wires through a single hole hiddent in the frame you built, and tape them in place where you want them, then cover the wires and backing with a thin black fabric, like speaker grill cloth. The lights should shine through the fabric just fine I would think... Any reason this wouldn't work?
