Hi everyone,
I've been a long time reader of AVS, and first I must say a big thank you to all the knowledgeable and helpful people out there, I have learned much from these forums.
So I am in the process of constructing a new house and have just gotten permission from the builder to do my own pre-wiring. I'm an electrical engineer and I work in electrical sales, so I think I should be able to handle the actual cabling and terminating as well as all the drilling etc. that is required. My question is regarding how to neatly/efficiently bring the homerun cables back into the electrical room.
The electrical room is in the basement of a 2-story house. The outside feeds from the cable and telco companies are here. For the cable runs up to the main floor and second floor, I plan on going vertically up (final location depends on what the framing is going to look like). So far, pretty standard I believe. There will probably be 20-25 Cat6 cables and 5-6 RG6 cables going up. I am wondering, how do you neatly bring all these cables out of the wall and the electrical room?
My first inclination is to install a 2-gang LV mounting bracket (like this: http://www.monoprice.com/products/product.asp?c_id=105&cp_id=10425&cs_id=1042507&p_id=7063&seq=1&format=2) and leave 4'-6' of cable hanging out of it. (This length is so I can easily connect it to a patch panel). Questions:
I would appreciate any insight you guys and gals have on my questions, and if you have any pictures of what your electrical room looks like and how the cables come out of the wall, that would be great!
Cheers!
- Is this the right approach? Or are there more proper ways of bringing so much cable neatly out of the wall?
- If this mounting bracket is the way to go, will leaving the 20+ cables of 4' - 6' spilling out of the box (since there's no way to coil this amount in the box) give the drywallers troubles? I don't want the drywallers to cut my cables because it's "in their way" or something like that
- Is there a recommended height to bring the cables out of the wall? For example, 12" from the ground, halfway up the wall, or near the ceiling?
- Is it recommended to bring the cables out of an interior (non-load bearing) wall so that I wont' have to worry about insulation installers cutting my cables?
- Another thought is to leave all the cables coiled up inside an interior wall with no other electrical boxes so the drywallers don't have to make any cutouts. Then they just put their drywall up, sandwiching my coiled cables inside, and when I am ready to pull them out, I just drill out a big hole and fish them all out. The studs are 24" OC so I would have lots of room between studs to "store" the cable
Cheers!
