Here is my current set up:
MOBO: GIGABYTE GA-H55N-USB3
PSU: APEVIA ITX-AP250W
CPU: Intel Core i3-530 Clarkdale 2.93GHz
Currently using the onboard GPU which has been fine so far, since I've only been using the HTPC for watching videos. When I built the thing I, stupidly, thought there was no way I'd use this for gaming. A couple years later, and I want to run some Steam games. Right now, I've only tried Super Meat Boy, which does run, it just runs slower than it should. I don't plan on running anything too intensive, but I'd like to be able to play arcadey types of games like SMB without any problems.
Is there a good video card I can get that will work with this small PC and not consume too much power? I did some searching and saw some people recommend the Radeon HD 6570. I don't know a thing about video cards. I just want to be able to run middle of the road games well on my HDTV. If need be, I can upgrade my PSU so I have more options.
Also, my case is tiny and overheats easily, so I don't put the cover on. Currently my PSU is just sticking outside the case, so, if I were to upgrade my PSU, could I potentially get a regular sized PSU and just let it sit outside the case as long as it is a 24 power pin like my MOBO?
Thanks in advance.
Thanks in advance.
