AVS › AVS Forum › Display Devices › Flat Panel General & New FP Tech › Newbie Needs Help!
Newbie Needs Help!
post #1 of 3
I'm going to purchase a Samsung UN46ES6500. I need some info on what I will need to set up my new tv when it arrives.
I currently have Time Warner's Basic/Standard DTV package with a Scientific Atlanta set-top cable box, and standard internet service with an RCA modem. I live alone and don't have a LAN set up. My company provides me with a Verizon mobile hotspot device for my iPhone and iPad.
Will I have to upgrade my cable service? It looks like my cable service already includes HDTV stations with my package.
Since TW now charges for the cable box, I was planning on purchasing my own box, but will I need a set-top cable box with this new TV?
Could I use my Verizon hotspot device for wi-fi for the tv, or should I set up a LAN?
Any advice will be appreciated!
post #2 of 3
You can use the hotspot if you'd like to connect to the TV. Be aware though that some applications do not allow access through mobile broadband providers. I'd recommend setting up a LAN connection regardless because most of the time you'll receive faster service and unlimited data.
As far as the cable box goes if HD comes included in your package, which it seems like to your knowledge it does, it all depends on whether or not the box itself is HD capable. I.E. has an HDMI output or component output. You should be able to do a quick google search with the cable box's model number and see if it is HD compaitble.
post #3 of 3
Many thanks for your helpful response!
