hi
i am buying an hdtv today ( a few hours) and need some advice.
which one should i get out of these ?
PN59D7000 vs PN60E6500
or would you go for TC-P60U50 + oppo bdp-93 to make up for the lack of video and audio decoders built in to the panny for example DTS,DTS-HD ETC..
i want to be able to play and decode any A/V codec i throw at it i know the oppo and the samsungs series 6's and up do.
so should i go sammy if so which one ?
will the cheap panny's picture be as good as the sammy's above ?
p.s.
i know the oppo is very expensive but i can get the cheap panny and the oppo for the same price as the sammy's.
i already have a un55c7000 and i dont want to downgrade PQ from this model already owned...
THANKS
p.s.
THANKS
