AVS › AVS Forum › Display Devices › Screens › DIY Screen Section › How much can I stretch a 54" piece of BOC
post #1 of 2
I want to make the largest screen possible. Going to have a rectangular frame with the BOC stapled to the front side (not wrapped around the back). How far can I stretch the 54" BOC so that it is stapled right to the edges of the frame? thanks
post #2 of 2
BOC does not have any stretch, you can only pull it "Tight"
Spandex stretches...about an additional 30% each way (2-way or 4-Way)
  Back to Forum: DIY Screen Section
