AVS › AVS Forum › Video Components › Home Theater Computers › Which codecs for an old Pentium 4??
post #1 of 8
Hí, i'm new here. xD
I found this forum trying to find a solution to my problem.
I have an old Pentium 4 witch an ATI x700 Pro Graphic card.
I've allways used k-lite codec pack to watch all my videos, included mkv's but I have seen that there are better solutions. However I don't know which one will be better for my configuration.
What do you think i have to install???
Lav filters? ffdshow? madVR whith lav filters?
Could you help me with this?
Greetings and thanks in advance
post #2 of 8
The bin. An Intel G550 is $35 at Microcentre, $45 elsewhere and is twice as fast as that CPU and GPU and uses half the power.
post #3 of 8
A P4 would be painfully slow as an HTPC. If you are on a budget, take Tiddle's advice but you're going to need a MoBo and some RAM and quite possibly a new HDD or SDD if you can squeeze it in. Add in the OS and you're up to $400 maybe.
If you cannot swing that does your mother board have PCIx slots or is it only AGP? If it has the former you may be able to use a newer graphicx card but I feel you'd be throwing good money after bad.
To answer your question, I recommend un-installing K-Lite and using Shark007. What OS and player are you using anyhow?
post #4 of 8
I recommend you use SAF Codec pack. The unlocked version will give you access to additional codecs that might work better on older hardware.
post #5 of 8
Add Radeon HD 6450 (as low as $30) that supports hardware decode acceleration for MPEG2 / VC-1 / H.264, so P4 should be good. Uninstall all codec packs. Install LAV Filters, that's all what you need, as well as MPC-HC.
But I think it's time to upgrade your system.
post #6 of 8
First i tell you, this PC is my Mom's PC which use occasionally to whatch some movies or series or some navigation on the internet, so i will not upgrade it. xD
The PC configuration is:
Pentium 4 3Ghz
X700 Pro Graphoc card Pcie
2Gb Ram
500 GB HD
S.O: Windows 8 64bit
So, should i install only Lav Filters, to reproduce all king of formats in the best quality?
I think codec packs are not the best solution.
Thanks in advance.
post #7 of 8
LAV Filters is the only filter set you will need (in most cases).
Your system can play most SD contents and MPEG-2 HD contents, but it can't play VC-1 / H.264 HD contents because neither CPU nor GPU can decode VC-1 and H.264 fast enough.
post #8 of 8
Thanks. You're ritght, i've be able to play some HD in 720p content with normal framerate which is all i need, but 1080p files is really imposible to play normally, but it doesn't matter to me.
I'll try Lav Filters then, thanks.
