AVS › AVS Forum › Audio › Speakers › Paradigm Millenia CT ($699) vs. Airmotiv 5 + XDC-2 ($758)
post #1 of 5
Hi all,
As the title suggests, I'm comparing the two systems. Any input will help!
Also, if you have other suggestions for max budget of $760, please let me know!
Edit: The title should read
Paradigm Millenia CT ($699) vs. Airmotiv 5 + XDA-2 ($748)
I was in a rush when I was creating this thread. Excuse my mistakes smile.gif
Edited by schung - 1/9/13 at 8:33pm
post #2 of 5
What's an XDC-2?
post #3 of 5
oops, meant to type xda-2. Silly me
post #4 of 5
Unless you have an expensive set of cans, you don't really don't need the XDA-2. It's a DAC and headphone amplifier. So you are paying for the headphone amp. The benefits of the balanced outputs will probably not make it worth the cost. You'd be better off to spend the money on speakers.
For that matter, many people on here might say that the ODAC and the Schiit Modi that I recommended in your other thread would be overkill (btw: stop starting new threads--it makes it hard for people to respond with all these different conversations). The ODAC has been tested extensively, and is show to be audibly transparent for reproducing the source. No need to go better than that. I've seen people compare the Modi to the ODAC who found them equivalent, which is why I recommended it as a cheaper, although less portable option.
post #5 of 5
Originally Posted by schung View Post
Hi all,
Which ones did you end up getting and how satisfied are you with your choice?
  Back to Forum: Speakers
