Originally Posted by
robertcharles
Did you have an LFE system previous to this?
I've had a few capable systems prior to this, but none that I would say would even compare. I've run dual 16-46pc+'s that were replaced by dual PB12/2+, which was replaced by a PB12/2 Ultra.
Also, were you happy with the overall impact of the speakers you have in place without an LFE?
Well, seeing as I've never run anything larger than M80's for my front stage that's subjective. I think the Axioms put out quite a bit of bass on their own; they are no slouches. That being said, I'm not sure an 8" driver (dual 6.5's actual equal 9" but I'm factoring in xmax as well), is going to keep up with these but we'll see. I've really gotten the DIY bug after this project and the front stage will be a ton easier to assemble than these monoliths.
I think I need to look up a good Chiropractor. I really should have brought some help over. I managed to rock and pull these up on to the stage and swing them up top where I rocked them into position. It is a very tight squeeze between these and the vertical support beams for my screen, but they should just clear with no issues. I thought about notching the beam but I figured I'd leave it alone.
