AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › What is the best duster to dust the screen of my Panasonic Plasma ST30
post #1 of 4
Is there a "best" duster on the market to safely dust the screen of my Panasonic Plasma ST30. Human hands have yet to touch the screen. Should I also use this duster to dust the black non -screen frame of the Plasma TV?
post #2 of 4
I do not use a swiffer duster as despite the good reports from some experienced posters here, swiffer uses a mineral oil coating. I am almost sure that this is perfectly OK. But why risk it? It may be fine for many wipes but I would simply use a good microfibre cloth, gently stroking the screen and, if you have some stubborn problem, add a bit of distilled water.
post #3 of 4
And if you used distilled water you should spray the cloth not the screen right:?
post #4 of 4
Yes, just on the cloth and not overly much. That method has never caused any issue at all.
