For those with the RW-12D Klipsch sub, do you use the Auto-On feature?
I've been manually turning on and off my sub, but figured might as well use the feature they put in there in the first place to do this.
Anyways, it says after 20 min of no activity, the sub will turn off.
I went into the LCD display and in the Power section, selected Auto On and then proceeded to shut everything down (TV, receiver, BD player), except for the sub last night.
I woke up this morning and I can still see the LCD is active showing the volume setting, however, the display was not lit up. As soon as I pressed a button, it lit up.
For those that use this function, does the display remain "active" after 20 min after you shut everything down? While it won't be lit up, does it still continue to show the volume setting?
