Klipsch RW-12D - Auto On Feature
15K views 133 replies 35 participants last post by  blunderbusdriver
#1 ·
For those with the RW-12D Klipsch sub, do you use the Auto-On feature?
I've been manually turning on and off my sub, but figured might as well use the feature they put in there in the first place to do this.
Anyways, it says after 20 min of no activity, the sub will turn off.
I went into the LCD display and in the Power section, selected Auto On and then proceeded to shut everything down (TV, receiver, BD player), except for the sub last night.
I woke up this morning and I can still see the LCD is active showing the volume setting, however, the display was not lit up. As soon as I pressed a button, it lit up.
For those that use this function, does the display remain "active" after 20 min after you shut everything down? While it won't be lit up, does it still continue to show the volume setting?
See less See more
#2 ·
Don't know never checked or cared. But I can tell you I use the auto on feature.
#3 ·
Can you please check your LCD display next time your whole system is off for at least 20 minutes? To see if the LCD displays the volume setting and the square boxes that represent the volume level? I would think that if the auto on feature didn't detect a signal for 20 minutes that it would shut down, which would include shutting down the LCD display.
#4 ·
I use the auto on feature and it still shows the volume after the system is off. I think thats normal but I may be wrong.
#5 ·
Originally Posted by cchunter  /t/1450950/klipsch-rw-12d-auto-on-feature#post_22812731
Thanks for the feedback. I mean the sub sounds great, but I'm wondering if turning it off/on using the actual switch on the back of the unit every day or every other day is bad for it, which is why I wanted to start using the Auto On feature.
I may call Klipsch CS tomorrow and see what they say, but chances are they'll say it's normal for the display to remain active during sleep mode to avoid any needed warranty repairs.
#6 ·
If you call let us know your findings. Because I'm not the sharpest tool in the shed I just assumed it automatically set itself to auto-on......didn't bother checking the menu. I saw your thread and checked and mine was on 'always on'....oops. At any rate, I switched mine to auto on and see that the display stays on also. I'm assuming it's normal but would like to hear what Klipsch has to say as well.
#7 ·
Originally Posted by highdefav1  /t/1450950/klipsch-rw-12d-auto-on-feature#post_22810003
I
Ive owned three of these and they all did exactly what your talking about, the first few times the auto off will actually work and the screen will say stand by after 20 minutes. I found that if I unplug it and leave it unplugged for a while plug it back in and will then work again but only for a few times. They always eventually continuously stay on.
#8 ·
I finally got through to a Klipsch CS rep and basically if there is any interference (electrical or through the sub cable), even the smallest interference, the sub will remain active...not go into standby mode, which keeps the unit on, but shuts down the amp.
According to the rep, it's not bad for it if it doesn't go into standby mode and stays "active" all the time.
He said you could try a different outlet, since some can emit low level frequencies which will cause the sub to remain active. Sometimes a long enough RCA/subwoofer cord can also cause the sub to remain active, because all it takes is the slightest signal, even through the receiver maybe off and the sub will remain active.
One thing I noticed is that on the cord there is a tag that indicates 10A 125V. All my circuit breakers are either 15/20/30 amps. Not sure, but maybe too much for the sub, so it's remaining active all the time? Or maybe that just means it needs a minimum of 10A 125V to run the sub.
#9 ·
I was told by other members of this forum that if the sub has a class D amp, use the auto setting. If the amp is a class A/B amp, turn it off when you are done using it.
#10 ·
Can anyone else comment on the "auto on" feature of the Klipsch RW-12D? What is your LCD indicating after 20 minutes or more of no signal from the receiver (meaning you have turned the receiver off and had it off for more than 20 minutes). Just want to make sure I don't have other issues or if it actually is the sub, put in a warranty claim.
I know there has to be more users of this sub, especially with the firesale that keeps going on at New Egg.
Further tests I did....
1. Unplugged the audio cable from the back of the sub and it still did not go into standby mode.
2. Unplugged the audio cable from the back of the sub and plugged the sub into a different outlet and it still did not go into standby mode.
Although I think both outlets I tried are on the same circuit, so If it was an electrical imbalance, I guess it wouldn't matter using one plug vs. the other. I guess I'll try a totally different plug on a different circuit..
#11 ·
Originally Posted by highdefav1  /t/1450950/klipsch-rw-12d-auto-on-feature#post_22823063
I use the auto on feature and it stays on all the time. I have NEVER turned the switch off on the back. Its perfectly ok for the sub to stay on standby all the time. I see nothing wrong and never had any problems with it by doing this.
#12 ·
Yeah, I have no doubt that it's ok to leave the sub on all the time when it goes into standby mode after 20 minutes of no audio signal. But mine does not and I get the jist that there are others that don't go into standby mode either.
And just the other day, I heard a loud thunderous noise and looked outside...blue sky as far as the eye could be. The subwoofer went off all of a sudden and while it was on (auto on, but not in standby mode) everything else was off (receiver, tv, bluray etc).
Does yours (cchunter) actually say Standby on the LCD? Or does it just show the volume indicator?
#14 ·
Hi guys,
I also have a question about the RW-12D's auto-on feature. I read that for some subs, to properly engage auto-on, you need to connect your sub cable from the receiver to both the left AND right line-ins using an RCA splitter. This is to strengthen the audio signal so that the sub can properly detect it and thus automatically turn on.
Is this necessary for the RW-12D, or can I connect my sub cable to just ONE of the line-ins?
#15 ·
Originally Posted by limsilas  /t/1450950/klipsch-rw-12d-auto-on-feature#post_22945144
Hi guys,
You can use just ONE line in and that would be fine.
#17 ·
I'm using an RCA splitter and have noticed that mine does indeed go into standby when not in use.
I haven't tested out how long it takes to go into standby so not sure if it's 20mins but the morning after, I went to check and it said 'standby on' or something along those lines. Checked it again yesterday after coming home from grocery shopping and it said standby on again.
#18 ·
I've just learned that mine hasn't been going into standby either. I have auto power selected and I have both left and right RCA inputs plugged in (my AVR has 2 subwoofer outputs). In the firesale thread they mention that it should say "standby" when it goes into it. Mine has never done this. It always shows the volume setting even when my system is off for hours or days.
I am going to try unplugging as someone suggested above and see if that resets things. I do use the power circuit it's on as a powerline network (my home network goes through the powerlines so that I can watch HD videos downstairs without any buffering). So I'm guessing that could cause some interference in the power line.
If the sub isn't going into standby I'm wondering how much power it uses being constantly on. I bought this last month and noticed my power bill was higher then average...enough to definitely notice a difference. Just wondering if this might have anything to do with that if it's on 24/7.
#19 ·
Originally Posted by boomster  /t/1450950/klipsch-rw-12d-auto-on-feature#post_22960060
That's interesting - it's kind of the opposite of the auto-on feature not working correctly when you going into only one of the RCA inputs. Maybe with both RCA inputs your sub is "too sensitive" and is detecting a signal even when there's not really one?
#20 ·
Originally Posted by limsilas  /t/1450950/klipsch-rw-12d-auto-on-feature#post_22960134
When I get home this evening I'm going to try a few different things to see if I can find out what it could be. One of the things to try is to just use one input, and then use a Y cable with just that one cable as well. Also going to try a different outlet. And think of anything else... like maybe put it on a power strip that has interference blocking features. Hopefully something will get it to go into standby again, and on a regular basis. I don't need another bill like last months.
#21 ·
Originally Posted by boomster  /t/1450950/klipsch-rw-12d-auto-on-feature#post_22960164
Good luck! Let us know what happens.
#22 ·
I dont think you'd hardly notice much of a difference if any at all in your electric bill IMO. Even if its still on its not doing anything and basically in standby without it saying standby if that makes any sense?
#23 ·
Like cchunter said...I can't imagine this sub is consuming enough power that you would notice a difference when the unit is on (not in standby).
I did a couple other tests and it still didn't go into standby.
I also recently bought a RCA splitter and connected the cable from the receiver into this RCA splitter and then plugged the splitter into both the R and L inputs on the back of the subwoofer....didn't make a difference.
I've actually decided to silence my OCD and just enjoy the sub and not worry about standby, on vs. off, etc....I just leave it on all the time now.
If something happens to it, I'll put in a warranty claim with Klipsch.
  • Like
Reactions: cchunter
#24 ·
Highdef I agree totally! Just quit wondering about it and enjoy. Its a great sub for the price regardless of this small problem.
#25 ·
Originally Posted by cchunter  /t/1450950/klipsch-rw-12d-auto-on-feature#post_22962367
It would make perfect sense, but that isn't the case.
I went and bought a Kill-A-Watt power meter out of curiosity and unplugged the RCA cables completely. Plugged the sub into the meter and I'm reading an average of 250 watts consumption without it doing a single thing! 250 watts 24/7 is nothing to think lightly about in my book. That's about a dollar a day at my energy cost. I'd expect that when it's playing something, but not when it's silent doing nothing.
I'm continuing to see if anything will put mine into standby. Unfortunately I have to wait 20 minutes after each thing I try. I do know at this point unplugging the RCA's completely didn't solve my issue so it must be in the power line somehow. I just plugged it into a power conditioner and hope to see if that makes any difference or not.
#26 ·
Originally Posted by boomster  /t/1450950/klipsch-rw-12d-auto-on-feature#post_22963885
I doubt if a power conditioner will make any difference but I guess it's worth a try. I would use a surge protector and turn it off when not being used.
At first thought, you would think Klipsch would have done more testing and engineered a better system but from what I've gathered most budget subs have problems with the standby feature. It's a little harder to understand though given the MSRP of the RW-12d. I don't know about others but this problem is one of the reasons I didn't buy this sub because things like that matter to me.
Al
