AVS › AVS Forum › Audio › DIY Speakers and Subs › Bookshelf speaker plans, 5 inch to 6.5 inch range?
post #1 of 6
I am looking to build a pair of nice bookshelf speakers. I have a pair of Overnight Sensations in my bedroom, and now I want to build up something a little bigger and use the OS at my computer. A pair of bookshelf speakers with a 5 to 6.5 inch woofer and tweeter sound great. But I don't know what's out there in this size range.
I heard several bookshelf speakers in a Magnolia room in Best Buy. Energy CB-20's sounded great to me, as well as a set of B&W speakers. Can I match or exceed the audio quality with a DIY build?
post #2 of 6
Budget? You can definitely stomp what's available at best buy.
I'm gonna guess around $350. The ZX Spectrum should be a good fit if you're a fan of the overnights
http://meniscusaudio.com/spectrum-pair-p-1296.html
Edited by Jay1 - 1/10/13 at 9:19pm
post #3 of 6
Budget. Hmmm. $350 is the top. Less is better. $200 to $250 is best.
Those Hi-Vi M6a woofers look very nice...
post #4 of 6
post #5 of 6
I am looking to make a pair of stereo speakers. Some of these look like they are for HT use with a sub. This build will be subless for music.
Edited by Lux - 1/11/13 at 1:30pm
post #6 of 6
Any of those will reach below 60hz ( the swope tm would need a ported box). If you're placing these near boundaries, the Aviatrix above will have very good bass to 40hz. You didnt specify a low frequency goal, only a woofer size and price. Other then the ZX Spectrum, some other options with deeper bass...
http://meniscusaudio.com/classixii-pair-p-1333.html
http://www.diysoundgroup.com/speaker-kits/kits/hitmakers-kit.html
