Sorry for the delay. I think you need to very carefully check the surrounds on both the woofer and the passive radiator. At its age they are likely to need replacing. It could be that when you are using it in your home with today's dynamic recordings they could fail the first time you use it. In the past I've picked up a number of subs off my local Craigslist and sorta played with them. I don't have a terribly high income unlike some of the folks here and I had a good time doing it. I bought all of them far below their value and flipped them at a small profit after playing with them.
If it were me and if you are in a larger metro area, I'd hold off until I found a Hsu, SVS or some of the other popular id subs popular on this forum. At least look for something with rubber surround. They show up sometimes at very good prices. Lately I've been seeing quite a few high quality DIY subs on my CL and that might be another idea. One other thing to look out for is amp failure there is a tendency in particular model subs of amp failures. Using the forum search engine here on one sub you are considering may save you some trouble. Best of luck in your search.
Edited by tulum - 1/11/13 at 12:53pm
