AVS › AVS Forum › Audio › Receivers, Amps, and Processors › IPhone APP for receivers
post #1 of 3
Which company has the most robust APP, basically it works all the time. My receiver will be on the LAN, not wireless. So wireless connectivity is not an ISSUE. just good APP programming.
thnks,
MitsMarty
post #2 of 3
the marantz app gets a lot of lousy reviews in the app store, but it has worked fine for me. i wish there was one specifically for the ipad though.
post #3 of 3
I talked with a Crutchfields sale person and he said Yamaha's APP is the most robust, thanks for the reply. regards, MitsMarty
