AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Channel Master CM7001 and Kinivo Switch IR code crossover: Help!
post #1 of 2
Just got the components above, set it all up with a Dune player and JVC projector and guess what:
6 key on the Channel Master remote changes the Kinivo switch to input 1a
Even better the 8 on the CM remote key turns the Kinivo switch OFF.
Any solution here besides returning the Kinivo or Channel Master?
Anyone recommend a 3D capable 4x2 switch with EDID presets?
Cheers and thanks for the help.
Edited by Chris Albert - 1/12/13 at 5:06am
post #2 of 2
No one's seen this before? Why would a manufacturer use IR codes that another device already uses?
  Back to Forum: Remote Control Area
