AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › please help... lg pa6550 or tc-p55ut50 ??????
post #1 of 4
Hi need help asap... going to buy a tv for the football weekend. both the lg pa6550 and tc-p55ut50 are $799 at costco right now. what is the better buy? the lg is 60" vs panny 55" but im sure the panny has better pq. any input would be a huge help, thanks.
post #2 of 4
anyone?
post #3 of 4
How far are you sitting from thr display? Yes, IMO the Panny has better PQ, but bigger is better, again depending on your seating distance.
post #4 of 4
IF you care about 3D, the Pan UT50 series offers it, whereas the LG does not.
Beyond that, this is a tough choice, given same price & larger panel for the LG.
Given CostCos excellent 90-day return policy, I would opt for the LG: it received a very good review from CR.
As BillP already noted, viewing distance is important - as is YOUR Normal Program Material.
If you sit LESS than 9 feet from the display, and/or Primarily view Non-Blu-Ray programming, the (Slightly) smaller panel might serve you better.
At 10 feet or out, or for blu-rays, would go with the 60.
