i am in the process of hopefully finishing up my build soon...and i could really use some direction on the following questions....some of these are trivial i am sure...but this is my first build and figured it is better to ask...
- i have primed and painted the top endcap flat black...do most people stop here or should i be placing some kind of coating over the flat paint...
- should i prime and paint the bottom endcap separately or after i have attached the endcap to the legs and the baseplate...
- i will be using 1 1/8" diameter round dowel legs...i imagine i can wood glue the legs to the bottom endcap...but should i just screw them into the baseplate...will one screw per leg be sturdy enough...
- for the binding posts...i used a 1/4" bit all the way through both endcaps and then used a 1/2" bit (?) to countersink the holes on the internal endcap...but this still does not leave much room for the wire terminal...can i just solder the wire right onto the binding post thread...or should i just work on making the hole larger and bend the wire terminal in a 90 degree angle upward...i have attached the link for the binding posts which i will be using...
http://www.parts-express.com/pe/showdetl.cfm?partnumber=091-1245
Edited by cnp112 - 1/12/13 at 10:51am
