AVS › AVS Forum › Audio › Soundbars › Vizio's New True 5.1 Soundbar S4251W
post #1 of 694
http://reviews.cnet.com/home-entertainment/vizio-s4251w-b4/4505-6449_7-35560754.html
post #2 of 694
I might buy this ! Wireless rear speakers !
post #3 of 694
I've been waiting for this and its larger brother since CES.
I started a thread on them, but there has been no news in all this time.
Having real rear speakers is better than any emulation, or beamed channels.
post #4 of 694
Do you still have to plug the rear speakers to the sub with it ?
post #5 of 694
If you click the link, you'll see that it says that the rear speakers are wireless.
post #6 of 694
Yeah I know, but could they mean that you don't have to connect it to the sound bar but it is wired to the subwoofer, which is wireless ?
post #7 of 694
I'm pretty sure, from what I've read since CES, that the rear surrounds are wireless, as is the sub...unlike the Vizio 510, which tethers the surrounds to the wireless sub.
As mentioned in the other thread, Philips is introducing a wireless 5.1 soundbar, but at a higher projected price point.
post #8 of 694
No new soundbar from Vizio, what is taking so long, it's now April 10th??? Disappointed in you Vizio...........
post #9 of 694
I'm impatient as well, but I do believe their new soundbars are coming.
post #10 of 694
Gotta watch out with wireless if you have other sources like an Xbox running. My wireless sub woofer interfered with Xbox live. Had trouble with wireless and my Roku as well. Plus, wireless just adds more RF to your surroundings which is not the healthiest thing already. I've reverted to being a wired guy myself as a result. Old can be better sometimes.
post #11 of 694
Apparently they'll be arriving Late April or early May.
Personally, given that the soundbar is likely to be used mostly with Movies, I'm not concerned about the additional radiation. Wired systems are a lot more complex than an easy to set up Wireless 5.1 Soundbar. They apparently produce low distortion and high ouput.
I'm interested.
post #12 of 694
The satelitte speakers are wireless to the soundbar but not to the subwoofer. frown.gif
http://store.vizio.com/documents/downloads/accessories/S4251W-B4/QSG_S4251WB4.pdf
Vizio also made a webpage fot it, with the mention coming soon : http://store.vizio.com/home-theater-1/s4251wb4.html
post #13 of 694
I read that document and you're right! It appears to follow the formula of their last 5.1 Soundbar, the 510, which also has the satellites tethered.
I wonder if the larger version uses the same method.
The forthcoming Philips 5.1 soundbar definitely has completely wireless rears. More money, though.
Interestingly, the Phillips uses a wireless technology that is similar but not identical to Bluetooth, and it appears that there will be less possibility of interference than with a Wifi based system.
Edited by taichi4 - 4/11/13 at 2:37pm
post #14 of 694
This Soundbar is now in stock on the Vizio site. I am disappointed to see there is no hdmi arc connection.
post #15 of 694
Already out of stock.
post #16 of 694
You should get the same sound quality using optical.
post #17 of 694
Received mine yesterday. The remote does not work. Vizio shipping me a replacement remote not a good start.
post #18 of 694
How does it sound is the more important question...
post #19 of 694
Does anyone know if I import this from either the US or Japan (holiday next month), Will the wireless devices be compatible for my use back home in Australia?
any advise would be great.
post #20 of 694
Strongly considering getting this unit, pending initial reviews and availability. Looks to be a pretty sweet unit that should be easy to set up.
Too bad on the first remote.. hopefully it's not a widespread issue.
post #21 of 694
The VIZIO new sound bar Model# S4251W the sat speakers connect to the sub, The Subwoofer is wireless
post #22 of 694
I have my TV on an articulating wall mount.
Can this, or any opthe soundbar, be mounted under (on) the TV itself?
post #23 of 694
Many soundbars are mounted on shelves below a TV.
post #24 of 694
Back in stock on vizio.com, just fyi
post #25 of 694
Also, if anyone is ordering this off Vizio's site, I was able to use coupon code REGVIZIO10 for 10% off the order, which was pretty sweet. Unfortunately, California tax just about brought it back to the full price..
post #26 of 694
Interesting. I just tried to use that code and it didn't work.
post #27 of 694
Worked for me. smile.gif Didnt buy it though. Haha
post #28 of 694
Make sure there's no spaces in front or behind the code?
post #29 of 694
post #30 of 694
I have diagnosed the problem with my remote control intermittently not working is a problem with the soundbar. I have a Vizio tv who's remote also controls the soundbar. When it works both soundbar and tv remote works but somedays the soundbar will not work with either remote proving it is not a remote problem. Vizio are jerking me around on this and are insisting they send a remote. I have lost confidence in the soundbar I have and will press for replacement once I have received remote.
  Back to Forum: Soundbars
