AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Onkyo TX-SR875 - HDMI source trouble (PC, Xbox and other)
post #1 of 4
I have a problem with connecting to the HDMI source.
I am currently have one working device via HDMI - satellite decoder.
But I need to connect PC and other devices.
The following sources is not working:
* ASUS EAH4350 (ATI) (PC)
* nVidia Corporation GT218 [GeForce 210] (PC)
* Raspberry pi (micro PC)
* xbox 360 (Gaming console)
My actual version of firmware:
Main: 87 1.08
MainUpdateMode Ver1.01/07615L
DSP 1st: SR8051 07601A
DSP 2nd: SR8052 07518A
DSP 3rd: SR8053 07518A
HDMI: 1.01/07706A
Video: 07606E00924ok
On the AVR display: No Signal
Can anyone recommend some firmware upgrade?
This receiver makes me mad, I'm disappointed. Wasted money. I do not recommend Onkyo TX-SR875.
People recommend to buy an HDMI splitter and connect to the TV for the picture and the sound separately to onkyo - for me nonsense.
post #2 of 4
Make sure to try each HDMI source device in each HDMI input on the AVR as one may work better for a particular source device than another. Also, HTPC connections can be tricky, sometimes requiring replacing the HTPC video board to make it work successfully. Although the following post was written with a Denon AVR in mind, you may still find the suggestions helpful to resolve your connection issue.
http://www.avsforum.com/t/1334369/the-official-denon-avr-xx12-model-owners-thread/0_100#user_L12
post #3 of 4
I am having similar problems with my 876. I've never done a firmware update and for some reason don't think this is the problem. I have a 600 and 805 that work very well so not sure if I am ready to throw in the towel on onkyo, but definitely disappointed with this issue.
post #4 of 4
Problem with Raspberry Pi resolved!
You need to disable EDID and set the resolution manually.
This should help raspberry pi users.
My WORKING /boot/config.txt:
hdmi_ignore_edid=0xa5000080
hdmi_group=1
hdmi_mode=4
hdmi_force_edid_audio=1
hdmi_drive=2
List of available video modes:
http://elinux.org/RPi_config.txt#Video_mode_options
Thanks for your help.
I like the term to describe the "hdmi_ignore_edid":
"Enables the ignoring of EDID/display data if your display is a crappy Chinese one".
They mean my AVR?
