This bar runs directly down the middle of the screen. It comes and goes, and not in any sort of discernible pattern. Just randomly appears and goes away. Panasonic TC-P46S2, less than two years old.
I have seen threads on fixing a black line / bar running vertically down the screen, and the fix was a cheap secondary board and a little handy work. A tech looked at my screen and said this issue is the panel. He didn't test it or open it up, he simply looked and said it is the PDP. I am curious if any experts out there can confirm things one way or the other simply by looking. If it is not the panel, is this something a fairly efficient, mechanically inclined person can fix on their own?
As you can see, sometimes the issue is a full two inch bar (last two pictures), other times it is merely a horizontal line running that two inch length, every inch and a half or so vertically.
