Greetings,
It's time for me to fill out my SEOS five channel system with a new sub(s).
As background, I upgraded an aging Pardigm 5.1 system with SEOS mains and sides, per below.
I had great input and inspiration from 'Lil Mike and dB-Kicker on making a 'lil Wrecker: http://www.avsforum.com/t/1417294/seos12-2512-build/210#post_22316836, but I'm thinking I'll need to go smaller and more conservative (i.e., easier build).
On size, my theater is roughly 17 x 21 and I need to add treatments and a screen wall so it's getting a bit cramped on "movie night". Smaller subs will be able to fit behind the screen wall and not encroach on seating space.
On the ease of build, I know this is relative, but I'm looking for the "easy button" on this build. I'm in a new job, traveling a ton, so I need the easiest path. To that, I have first hand experience with DIY Sound Group's flat packs versus full DIY, and can attest to the ease. Erich's flat packs are pretty much "paint by numbers". Just the level of ease I need.
Special thanks to 'lil Mike and dB-Kicker for their ongoing interest and support in my sub planning.
So, here are the current plans:
As far as similar builds, I'm looking at James, Fade to Black, and Gorilla83's build threads for info and inspiration.
- Mains. http://www.avsforum.com/t/1417294/seos12-2512-build
- Sides. http://www.avsforum.com/t/1437288/seos-surround-build
- Number of Subs. Ultimately two, but may build one at first.
- Driver. RSS460HO
- Sealed. The 460 seems to do well sealed and in a lot less space.
- Single/Dual. Single. I don't think I have the room, money, and/or know how to do a dual.
- Box. Erich is working on a specific box for the 460, but it will be similar to the 4.5 cu foot flat pack. I believe the final box will be closer to 4.0 cu ft.
- Amp. I bounce around a lot on this. First, do I go plate or external pro amp? Second, leaning toward pro amps, I'm thinking Behringer NU3000DSP with an Art Clean box pro.
- James' Build. http://www.avsforum.com/t/1433137/from-endless-contemplation-to-fruition-james-first-diy-18-sub-how-low-can-you-go-wise
- Fade to Black's Build. http://www.avsforum.com/t/1439450/dayton-rss460ho-reference-18-subwoofer-sealed-build-thread
- Gorilla83's Build. http://www.avsforum.com/t/1435795/first-diy-project-for-a-guy-looking-to-upgrade-multiple-sealed-18s
With cranking out 8 of this bad boys, you have to be wiped out.
