AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › What are your general thoughts on the Polk DSW PRO 440 WI and 550 WI Subwoofers?
post #1 of 6
Looking at these two subs, as I can get the 440wi for close to $200 shipped and the 550wi for $300.
I'm not wanting a comparison thread, or suggestions of other subs. I just want to know what the general consensus is on these things.
The price is right in my alley, as well as enclosure size.
The specs look good on Polk's website, so I'm just curious if anyone has any experience with them for home theater.
Thanks in advance!
http://www.polkaudio.com/products/dswpro440wi
http://www.polkaudio.com/products/dswpro550wi
post #2 of 6
post #3 of 6
For that price I say go for it. If you dont like it you could always sell it for what you have paid for it. Good Price.
post #4 of 6
Decided to give the 10" a try. Couldn't pass it up at the price, and the reviews have mostly been positive. Specs and overall build quality seem great at the $300 price. But would be hesitant at full retail.
Anyway, I should hopefully have it delivered (from Newegg) by Wednesday. Waiting is the hardest part.
post #5 of 6
Received my DSW Pro 550wi yesterday. The UPS driver noticed a gouge in the box and hung out with me for a few minutes while we opened it up and inspected things. Everything was fine though; no damage.
I purchased it on Newegg, but it looks like their "sale" is done and it's up to full $499 retail now.
Anyway, I haven't had any time yet to really test things out. I managed to listen to a little Metallica (Master of Puppets) and watch a few minutes of the new Dredd movie.
Not going to comment on sound yet, because it's not properly adjusted and not broken in yet. But I will comment on aesthetics and operating it.
What I like:
  • It looks nice. Sleek flat black, rounded corners with simply a lighted Polk logo on the bottom. Understated and nice.
  • You can configure it either as a down-firing or a front-firing sub. Very versatile.
  • Comes with a remote control for adjusting it from your seating position. This also allows you to run an "adjustment" on where it's placed: in the corner, against a wall, or in a cabinet.
  • Wireless capability.
What I don't like:
  • No volume control knob. It gives you an "up" and a "down" button for volume that you have to press repeatedly to adjust. It's like this because you can adjust the volume from the remote, but in all honesty I hate it. Takes way too long to adjust the volume. There is also no display telling you what volume it is at. Instead, the Polk logo flashes codes that tells you what volume it's at that you have to look up in the manual.
  • It's a little large, but I was kind of expecting this.
  • If you want to change it to a front firing sub, the amp side now faces down. Which means you should probably get a 90-degree RCA adapter and a 90-Degree power cord. Also, if you want the driver covered, you must separately purchase a grille for $50.
My initial impression of this sub is that it's a decent product. Solidly built, good sound (from what little time I had to play with it) and full of nice features.
I'll follow up a little more once I've had the time to dial it in and test it out properly.
post #6 of 6
Over the past several days, I've had the chance to test this sub out a little more. Still haven't been able to dedicate myself to a full movie yet, but I'm getting bits and pieces from different movies and music in with my free time.
I have this subwoofer placed in an awkward spot, inside of a cabinet under the TV. It's really the only WAF designated space in the room. At least I can open the cabinet doors though.
The fact that this subwoofer can be either down-firing or front-firing helps in this situation, as well as it's ability to alternate phase from 0, 90, 180 and 270. The "room correction" adjustment also really helps with the sound, much more so than I thought it originally would.
Sometimes you can't tell what is going to be a gimmick, and what is going to provide actual functionality. In this case, I set the room correction to "cabinet", and it really did make a dramatic impact on the quality of the sound while having it located inside of the cabinet.
So far in my testing for movies, (keep in mind, I'm just an amateur and using my ears and butt as the measuring instruments) I've watched some Avengers, The Dark Knight, Tron Legacy, Prometheus and Dredd. What I like the best about this sub so far is how hard it hits. The sound is very tight and articulate. No inane rumbling or or flabby sounds. When a punch is thrown, you feel it. When a gunshot is fired, you feel it. When a vehicle's exhaust roars by on screen, again, you feel it. You feel these when they happen, and you feel the impact of them. Not just low end grumble, but tight, punchy and distinct bass.
With extended periods of low bass lines, especially in Prometheus, it again does very well in being tight and articulate. My old Dayton sub would sometimes flail out of control with no real visceral feel to it. The tightness of the 550wi definitely stood up to the opening scene in Prometheus.
With music, it's definitely better than the Dayton. I think this much is apparent because of the fact it can hit so hard. Definitely helps with rock/metal music. Drum notes are distinctive, and bass lines are pronounced well without getting out of control during faster music. I listened to a bit of older Metallica, Filter, Frontline Assembly and The Eagles. What impressed me the most was The Eagles. With the "country" style drones of the bass guitars... Wow. Every line shook another part of my body.
Electronic beats with Frontline Assembly were powerful and again, well pronounced.
I don't normally listen to a lot of music at home, but this is compelling me to start doing it more often.
Adjusting this subwoofer took a while. Constant battles with the volume level, phase control and room placement corrector frustrated me at first for a while, but once I got it dialed in for the source I was watching, I didn't have to touch it.
The only complaints with the 550wi so far in regards to sound quality, is when the really really low notes hit. You can definitely tell when it drops off. The low frequencies are still there, but not as prominent as they were. Overall though, it's still light years ahead of the Dayton's performance.
So, someone coming from a low-end sub would most definitely be happy with the 550wi. While someone coming from something in the $500+ Internet Direct price range might be disappointed.
All in all though, having this sub blended with my Paradigm Monitor 7 towers makes for a wonderful home theater experience. If you can get this sub on sale (As I did), I would recommend it. I purchased mine at Newegg for $329 shipped. But, I'd be hesitant to do it again at the regular $499 retail price.
Once you get up to that $500 subwoofer range, so many other and slightly better options start to open up.
