Originally Posted by
Despoiler
Augerhandle
Now you're just being silly. HD is is an industry standard. Lookup the spec if you don't believe me. Netflix is bastardizing the industry nomenclature for their own marketing purposes.
Done.
http://en.wikipedia.org/wiki/High-definition_video
High-definition video is video of higher resolution than is standard. While there is no specific meaning for high-definition, generally any video image with more than 480 horizontal lines (North America) or 570 lines (Europe) is considered high-definition. 720 scan lines is generally the minimum even though many systems greatly exceed that. Images of standard resolution captured at rates faster than normal (60 frames/second North America, 50 fps Europe), by a high-speed camera may be considered high-definition in some contexts.
Also from wikipedia:
"HDTV may be transmitted in various formats:
1080p - 1920×1080p: 2,073,600 pixels (approximately 2.1 megapixels) per frame 1080i - typically either: 1920×
1080i: 1,036,800 pixels (approximately 1 megapixel) per field or 2,073,600 pixels (approximately 2.1 megapixels) per frame
1440×1080i: [1] 777,600 pixels (approximately 0.8 megapixels) per field or 1,555,200 pixels (approximately 1.6 megapixels) per frame
720p - 1280×720p: 921,600 pixels (approximately 0.9 megapixels) per frame"
http://tech.ebu.ch/docs/tech/tech3299.pdf
Page 7, I believe, also lists the HD formats.
You will not find Super HD listed at either site, because there is no such thing. The next step up is being called 4K, or UltraHD.
Edited by Augerhandle - 1/16/13 at 9:09pm
