Hey, thanks for the wealth of info here. I want better sound, not groundbreaking super audiophile grade, but clean, full, and non-fatiguing. My den is WxLxH 14 x 23 x 9 and extends into a 15 x 15 kitchen/breakfast area. A pretty large space. Carpeted in den and hardwoods in kitchen/breakfast area. Movies/TV = 70% - Music = 30% but might increase with new system
My budget is ~ $1300.00. I presently have the room set up with the TV (mounted on wall low profile) and console (also mounted to wall 16" deep) on a 14' wall with the couches 13' back and 10' open space behind me into the kitchen. Open floor plan
I'm using a 5 x 80watt Denon avr-1713 and have a HTIB take classic 5.1. I did all the in-wall wiring and all speakers are wall mounted. It is a temporary speaker solution and will be going to a small bedroom. It falls way shy of filling my room with sound for obvious reasons.
Note: WAF is important. This is not a dedicated HT. One day maybe.
I've been doing my research for about a month now...OCD is a terrible disease...
I've been drawn to Arx, KEF, AscendAcoustics, PSB, NHT, Monitor Audio, Wharfedale, and the list goes on. It is overwhelming.
Since the speakers will be wall mounted I've found what I think are satisfactory packages and think they will both be a monumental upgrade over the take classic htib.
1: NHT - I spoke with John at NHT and we configured a system that consisted of ClassicTwo LR, ClassicTwoC C, SZ2.0 surrounds, and B10d sub. This rung up to $1400
2: PSB - Alpha B1 LR, Alpha C1 C, Alpha LR1 surrounds, SVS sb-1000 sub. $1300
For now, I'm stuck with wall mounting the speakers although my mounts do hold the speakers 6-8" off the wall.
Recommendations? Are stands the only "real" way to achieve entry level audiophile grade performance? Any other nice entry level options y'all would advise?
) that with the keyhole and 2 1/4" threaded inserts that the Alpha 1's could be wall mounted. Should the ports be filled then if they are ~6" from the wall? For the Alpha LR1's they would be mounted on the long 23' side wall but pointed forward to the TV. I have the take classics mounted this way and the rear port is about ~13" - 15" from the wall:the LR1 would be almost identical and mounted to same mount. The center would rest on a pinpoint AM15 center speaker mount and the rear would be ~8" from wall that TV is hung on and below it at ear height. Common sense tells me that the ports are expected to be filled when wall mounting these Alphas.
so I feel like any rear ported "not made for wall mounting speaker" would be cheated by doing so.
