AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Question about running different wires along side each other.
post #1 of 2
I want to drill some holes along all the studs from the rack closet, around to the screen and past it so I have speakers and sub connects on each side of the screen. I need to run speaker wires (12g monoprice), RCA cables for the subs (also monoprice), and also 3 very long USB cables (monoprice yet again, BUT, with a range extender built inline). Can I run them all in the same holes in the studs? I know not to put any wiring near the electrical wires, but will I get any humming, buzzing or any other type of interference if I have these 3 different types of wire along the same set of holes in the studs?
Thanks for any info!
post #2 of 2
You should be just fine doing what you describe.
RTROSE
