AVS › AVS Forum › Audio › DIY Speakers and Subs › Lilmike's LilWrecker
Lilmike's LilWrecker - Page 12
post #331 of 525
http://www.menards.com/main/building-materials/panel-products/specialty-panels/hardwood-plywood/3-4-classic-birch-paper-back-plywood/p-1974681-c-13334.htm
Bought this today. Looks great and was on sale!! Thoughts?
post #332 of 525
Originally Posted by jpmst3 View Post
Mike, is it possible to have the mouth exit out of the sides instead of the end?
Not with this fold, L45 would be too short.
post #333 of 525
Should work fine as long as the PL sticks to the LDO. No experience with PL and LDO, or anything and LDO for that matter, so I'd suggest a test joint to make sure it works.
post #334 of 525
Gotcha. Thanks for the info.
post #335 of 525
Will do. Thanks!
post #336 of 525
i so want to build this beast! will the eminence lab 15 sub work? this sub is specifically built for horns. just wondering. i have 2 new ones sitting here collecting dust.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=290-575
PRODUCT SPECIFICATIONS
Power Handling (RMS)      600 Watts
Power Handling (max)      1,200 Watts
Impedance      6 ohms
Frequency Response      20 to 125 Hz
Sensitivity      88.5 dB 1W/1m
Voice Coil Diameter      3"
Magnet Weight      160 oz.
THIELE-SMALL PARAMETERS
Resonant Frequency (Fs)      28 Hz
DC Resistance (Re)      4.9 ohms
Voice Coil Inductance (Le)      3.23 mH
Mechanical Q (Qms)      5.36
Electromagnetic Q (Qes)      0.37
Total Q (Qts)      0.35
Compliance Equivalent Volume (Vas)      3.70 ft.³
Mechanical Compliance of Suspension (Cms)      0.11 mm/N
BL Product (BL)      26.7 Tm
Diaphragm Mass Inc. Airload (Mms)      308g
Maximum Linear Excursion (Xmax)      11.8 mm
Surface Area of Cone (Sd)      823.7 cm²
MATERIALS OF CONSTRUCTION
Cone Material      Coated Paper
Surround Material      Foam
Voice Coil Wire Material      Copper
Voice Coil Former      Aluminum
Basket / Frame Material      Cast Aluminum
Magnet Material      Ferrite
MOUNTING INFORMATION
Overall Outside Diameter      15.34"
Baffle Cutout Diameter      14.00"
Depth      7.75"
# Mounting Holes
BOX SIZE (MODELED WITH BASS BOX USING HIGH FIDELITY SETTINGS)
Sealed Volume      0.69 ft.³
Sealed F3      68 Hz
Vented Volume      1.79 ft.³
Vented F3      40 Hz
post #337 of 525
i'd say yes. gray is lab15. in room response will throw things off by more than the difference in drivers. check your cutout dimensions though...
edit: actually, i didn't change the voltage for the lab15, so the real spl is about a db or so lower the whole way across. no biggie.
Edited by LTD02 - 11/13/13 at 12:31am
post #338 of 525
thanx for the input. which do you think will perform better between the alpine sub listed in this thread or the eminence lab 15 driver? wish i could afford those high end lms subs. way out of my price range lol. this is my first bass horn build. very intrigued to say the least
post #339 of 525
nobody modeled it up yet?
post #340 of 525
here you go. sws15 in dark gray vs. stocker in light gray. no adjustment made to input voltage for minor difference in re.
so...i suppose that i'd say either will work, but the sws has slightly less ripple in the response. room effects will dominate in either case.
post #341 of 525
very nice. sounds like the alpine is an excellent driver for this build. especially for the money. right now im debating on building some waveguide monitors with AE drivers and a seos 12. wonder if this massive bass horn would match well with those monitors. i dont care if they do or not... i must build a bass horn!
post #342 of 525
"i must build a bass horn!"
post #343 of 525
well... do they!!! ;)
post #344 of 525
Originally Posted by SASSAFRAS KING View Post
If not, it isn't the sub's fault.
I'd suggest a peek at post #9. Those are JTR Triple8s, and the subs do a fine job of keeping up with them. I listen to the LilWrecker's little brother with my bottom-shelf E-waves, no complaints here either. Once the subs and mains are matched well (EQ, delay and phase), the integration is quite good.
As far as the Lab15 working in this cabinet? That's a driver I had considered for this cabinet from the initial concept, I just forgot to mention it in the first post.
Biggest issue I have with the Lab15 is that they're not exactly cheap for what they do.
According to PE, they're $280, and they have 12 mm of xmax.
$280 for a 12 mm driver? What is this, 1996? I can get 15 mm for half that $$ from Alpine, I can get 22 mm for $100 less than that from Stereo Integrity, and I can get 28 mm for nearly the same money from Fi, but they do work fine. If I had them, I'd use them, but if not, I'd probably look at the alternatives first.
post #345 of 525
I was thinking the same thing. If you have them lying around, by all means use them. If not, they are way overpriced regarding performance...
post #346 of 525
i have a pro audio guy that wants to buy these lab 15's from me. im gonna sell them and use the monies to buy materials and a new sub. so... is the alpine a safe bet or do i need to splurge a little for better output and sound quality?
post #347 of 525
"I was thinking the same thing. If you have them lying around, by all means use them. If not, they are way overpriced regarding performance..."
might want to be careful before jumping to conclusions...the lab 15 might be spec'd with overhang method only, so it's real xmax could be in the upper teens. still not spectacular, but a maybe not so bad as it seems on the surface.
post #348 of 525
True enough. Although, I thought I remember seeing the tested figure somewhere that was not so flattering. But, I could be confused as well.
post #349 of 525
Regardless of the overhang vs linear BL version of determining xmax, the Xlim is specified at 22 mm.
The Alpine SWS has a manufacturer-specified xlim of 34 mm.
Motor linearity aside, the point where the moving parts slam into the stationary parts is a place I'd prefer to avoid, because when that happens, the fun's over till the credit card comes out.
post #350 of 525
"i have a pro audio guy that wants to buy these lab 15's from me. im gonna sell them and use the monies to buy materials and a new sub. so... is the alpine a safe bet or do i need to splurge a little for better output and sound quality?"
No one's complaining with the Alpines, they measured fine and perform well.
No one has complained about the Stereo Integrity drivers either.
Only issue with the CVXs is the price. When I designed this sub, the street prices were half what they are now. At the current price, I can't recommend them.
As far as I know, that's it for the drivers that have found their way into this design.
post #351 of 525
i seen several Kicker 2010 CVX 154's on ebay cheap. might be worth trying. i know what those subs can do. they will shake the fillings right out of your teeth lol
post #352 of 525
here goes one for all the JL Audio fanatics. the JL Audio 13W7. one of the most over priced subs of all time. they have done nothing with this design for over 10 years. still their high end sub. wonder if this sub will work in a bass horn. i do know these things can move some serious air. zero bottom out.
http://mediacdn.jlaudio.com/media/mfg/9013/product_image/thm/t287_x2_c0cd0b95d6b65fc40ae3e3a44a6621b3.jpg?1384473631
Free Air Resonance (Fs) 23.5 Hz
Electrical “Q” (Qes) 0.476
Mechanical “Q” (Qms) 7.517
Total Speaker “Q” (Qts) 0.448
Equivalent Compliance (Vas) 3.68 cu ft / 104.3 L
One-Way Linear Excursion (Xmax)* 1.25 in / 32 mm
Reference Efficiency (no) 0.27%
Efficiency (1 W / 1 m)** 86.3 dB SPL
Effective Piston Area (Sd) 107.35 sq in / 0.0693 sq m
DC Resistance (Re)*** 2.41 Ω
post #353 of 525
I think the goal of all these designs is to get the most bang for your buck. The JL is priced in a category where there are much much better driver choices available for a horn.
post #354 of 525
At $1200 MSRP?
Sure, they work, but not in this design without some changes, and believe it or not, they're a little light on motor strength for a tapped horn....
I'd take the LMS Ultra and keep the change, thanks.
Edited by lilmike - 11/14/13 at 3:50pm
post #355 of 525
i use the alpines in the micro wreckers lilmike designed and they work great , the wood is more exspensive then the driver.
i push mine to the max for hours on end ( i dj with mine ) and i have yet to burn up a driver or have any compliants , and i can bet u im push mine much harder then those that are using them as ht subs
btw make sure u house/building can handle them lol
heres 6 inside a 3k sqft room not even at full power
heres 3 of them pointed into a hallway with windows for shits n giggles , u can see the windows flex
lol ive managed to break all the windows on the back of my building ( we were replacing them anyways ) i now have the new windows covered in rubber/foam pads
post #356 of 525
wow!!!! thats some serious bass!
post #357 of 525
Sub is complete. I had it built and have yet to pick it up. Initial looks from the pics he sent me are excellent. He said he watched a movie on it with a bash 300 watt amp and it was impressive. I should have it in my possession next week.
post #358 of 525
Played some 3 second sine waves at 15hz today at a very careful volume. Wow! I've spent too much time enjoying my LilWrecker and not enough time doing stupid stuff with it!!
post #359 of 525
I picked it up today. Guy that I had build it did an excellent job. Plywood with ebony stain and routered edges. I haven't had a chance to let her rip yet (too late) but I ran audyssey and so far so good. It is a monster!!!!!!!
post #360 of 525
Nice build!
