The problem: the sub hums as soon as a cable or satellite box is connected with the system. Pull the HDMI out of the cable/sat box, and everything is fine.
So we tried everything to get rid of the hum in the first house...pretty much everything that comes up in Google under subwoofer hum...and nothing worked. Had the power company out....cable company....independent electrician...spent months on it, and nada.
So now we hauled this beast to a whole new home (80 miles away), and hooked it up to a completely different system. We did not re-use a single cable, not even the sub power cord.
The result: identical hum.
And once again, it goes away as soon as we unplug the TV source. First was cable, second home is on satellite.
Any ideas? I'm at my wit's end....
PS - one symptom - the hum changes pitch quite a bit when you toggle the crossover switch on the back (regardless of Hz setting)...not sure if that's relevant.
edit - also, this sub came with a 2 prong cord...shouldn't a sub have a grounding plug?
Edited by Quill - 1/13/13 at 10:48am
. I'll be out on the weekend, and give them a shot! Thanks for the input--I'll post back with the outcome.
