Originally Posted by
butie120
Ugh! Waiting for the 1613 to go down in price is killing me. Trying to be patient is difficult sometimes...
You should SERIOUSLY check into the used/refurb market while waiting then. Takes the edge off and more often than not you will find a better AVR for the same or less than what you are looking to spend.
As for the 75 watts, believe it, that gets loud. Not crazy loud, but very loud just the same. Many times you will watch a movie with it 3/4's turned up and that will give slightly louder than 'normal' levels and is quite normal while still leaving headroom. Ebay can be great...an AVR 2310 (Denon) from there for under $130 shipped, 105 watts/ch there. My sister loves it. Was a grand when new.
Just food for thought...
