AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › DVR ES35S issue
DVR ES35S issue
post #1 of 10
Is this forum still around and is there anyone here who might help me with repair issue?
The subject DVR just went belly up after wife deleted a recording on a RW DVR which she has done many times before. This time, however, the unit went into a no response mode. A message was flashed on the screen saying U61 and then said something about unit not able to reset itself and refer to service manual.
I could not find service manual for this device on Panasonic web site.
I have been reading some old threads about electrolytic capacitors going bad. I now have the board where the power supply resides removed from the unit but do not see any signs of leaking capacitors.
Are there any other suggestions or should I just proceed with replacing the capacitor C11108?
Any suggestions will be greatly appreciated. Wife really misses here DVR and there really isn't something to replace it.
Thank you.
post #2 of 10
Correction: The model number is a Panasonic DVR-ES35S
post #3 of 10
Sure of that model number? Could it be DMR-ES35S?
post #4 of 10
In any discussion it's important to get the model number correct. Your Panasonic is probably a DMR-ES35Ss as Panasonic does not have a model DVR-ES35s.What you have is a DVD Recorder, not a DVR. (A DVR does not record to removable media, i.e., DVDs.)
The U61 and U88 errors are defined in this post:
http://www.avsforum.com/t/1158210/u61-error-when-off/0_60#post_16719887
This post adds the definition of the U99 error:
http://www.avsforum.com/t/1007613/official-panasonic-dmr-ez28k-thread/480_60#post_17163187
This post comments on the F60 error possibly followed by the U99 error:
http://www.avsforum.com/t/1158210/u61-error-when-off/0_60#post_16856463
Panasonic Service Manuals don't address component-level repairs for DVD recorders:
http://www.avsforum.com/t/1007613/official-panasonic-dmr-ez28k-thread/480_60#post_16832715
DVD Drive "no read," basic diagnostics and DVD Drive routine service procedures are found in this post:
http://www.avsforum.com/t/1055071/panasonic-2006-and-newer-dvd-drive-hub-spindle-cleaning-and-reassembly-complications/0_60#post_14479898
Edited by DigaDo - 1/13/13 at 5:09pm
post #5 of 10
I cetainly could be the capacitors, but it could also be the laser assembly. In that case, I would recommend you aend a PM to MICKINCT about your issue. He is the go-to guy for these kind of repairs.
post #6 of 10
Thank you for replying to my cry for help. Sorry about messing up the model number and you are correct. It is DMR-ES35S. I am newbie to this and really any forum so I guess went into overload.
I just pulled what is reportedly a problematic electrolytic capacitor and am going to replace that and I will follow up on the links you have provided.
Thank you very much.
post #7 of 10
Thank you very much for your reply. Nice to know somebody is out there and heard my cry for help.
I just pulled the C11108 electrolytic capacitor this morning and going looking for replacement. Will see what that does if anything.
One symptom I forgot to mention was when powering up the unit, the laser head would travel to the spindle repeatedly about 4 times and on the last, the spindle would rotate for about 1 second then stop.
If that is helpful, please let me know.
Also, I am a newbie to this and actually any forum. Never used one before. You mentioned in your reply to send a PM to MICKINCT. Sorry to display my ignorance, but what is a PM? and how do I do this. Sorry for such an elementary question, but as I said I am just beginning on this forum stuff.
Thank you so much for your help and patience.
post #8 of 10
Click THIS link and hover over the name mickinct in the second post(left side of the screen) and one of the options will be send PM. Click that and write him a note. Only Mick will see it.
From your newest description I'm strongly thinking you have a bad laser assembly which Mick can fix for you. I'd PM him before tearing anything more apart, I don't believe the capacitor is your issue and you don't want to break anything requiring more time and money from Mick smile.gif
Your Panasonic is quite a nice model and IMO it's well worth fixing. I also believe the model number should be ES-30v where the V means VHS since it's a combo. It may also have a S in the model which would indicate it's Silver in color, black Panasonics have a K in the model number.
post #9 of 10
Yes, it could be a failed laser assembly. Or, it could be as simple as a dirty laser lens. See this post:
The noises made by the DVD Drive as it attempts to locate or read a DVD help one determine the nature of the problem.
post #10 of 10
That is a very bad sign. If it sounds like THIS, then you almost certainly have a bad laser assembly. This is just not fixable, anymore than you would repair a burned out light bulb. You replace it, and that is what MICKINCT will do for you.
  Back to Forum: DVD Recorders (Standard Def)
